Old 06-12-2013, 06:43 PM
Alokocat Alokocat is offline
Alokocat is on a distinguished road
Default Re: CAT 374D L
Is that shelf dust or work dust on the grader?
Good zone Joe !
Dont know what to say in front of such skills.....congrats on a fine build. Hope to see more videos of it please.
Old 06-13-2013, 03:16 AM
That's beautiful! Your builds just keep getting better and better with every update. I never grow tired of seeing all the details. Very impressive!
Old 06-13-2013, 09:23 AM
Morghan Morghan is offline
Morghan is on a distinguished road
You're an artist ....
Old 06-16-2013, 05:32 AM
I finally got the TIG, still need to get the argon bottle and then start practicing
Old 06-16-2013, 06:45 AM
Woohoo right on! Looks like it has a lot of adjustments. Now hurry up and weld that cab together.
Old 06-17-2013, 08:28 AM
Lars S Lars S is offline
Lars S is on a distinguished road
Hey! I thought Kemppi was Finland! ;-)
Old 06-17-2013, 11:11 AM
It is, but it's over my price range
Old 06-21-2013, 08:56 AM
oldwestrnwear oldwestrnwear is offline
oldwestrnwear is on a distinguished road
this is a beautiful work of art
thanks perry
Old 07-05-2013, 04:58 AM
Not much to report here I've been disassembling the excavator for easier painting.
I also have been practicing tig welding with varying success
I can weld aluminium over 2mm thick, but I'm struggling with thinner materials when welding corner and but joints. Especially when the other part is narrow and other is bigger I tend to melt the narrow part through
I was trying to weld the cab side to the front window frame which is about 6mm wide and it melt through
Old 07-05-2013, 09:16 AM
I've definitely been there! The only difference is my pieces weren't as pretty as yours before I ruined them.lol You would think that it would be easy but it's really not. I think I have improved with time(you will too) but I've also learned that there are some things that "I" just don't have the ability to weld. I often weld pieces together before cutting out windows or drilling holes. This often makes the welding possible but the hole cutting a pain in the a$$. I also sometimes make small parts oversize and trim them to the proper shape or size after welding. All that makes the job more time consuming but there is nothing worse than spending hours on a part only to melt a big hole in it and having to start again!
Reg
Old 07-05-2013, 11:49 AM
Reg
Thanks Reg, you gave me several good advices there. I actually went through your Volvo thread yesterday to see how you did your cab. I will try to make the window frame oversize, that might make the welding easier
Old 07-27-2013, 04:15 AM
Excavator parts degreased and ready for painting
Here's everything except the hydraulic lines.
Old 07-27-2013, 09:53 AM
rc_farmer's Avatar
Master Builder
Truly a masterpiece!
Giving up is not an option!!!
Rob
Old 07-27-2013, 10:35 AM
speedy8305 speedy8305 is offline
speedy8305 is on a distinguished road
Darn this paint needs to speed up lol cant wait to see the finished product been watching this awesome build since post#1
Old 07-27-2013, 03:23 PM
With your parts all cleaned and degreased, laying out on the bench.....it gets me wishing this was a kit, and it was laying on my workbench!
Old 07-28-2013, 12:21 PM
Yea that sounds like a good Idea you should turn it into a kit (reasonablly priced)
Old 07-28-2013, 02:02 PM
Looks like you got that cab welded up. How do you like the welder?
Old 07-28-2013, 02:42 PM
The cab is not done, what you see in the picture are just some cross members that I welded between the sides to help welding the actual outer surface, that I haven't even done yet.
The welding machine is ok but I still have a lot to learn
Old 07-28-2013, 04:25 PM
You'll get it. Does the welder have a pulse setting? I find it helps to use it on the thin stuff sometimes especially with longer beads. I am using .050 5052 aluminum on the boat that I'm working on and it seems to weld OK but I definitely have to be more careful than with the .063 that I'm used to. How thick is the cabs sheet metal?
Reg
Old 07-29-2013, 05:38 AM
Madda Madda is offline
Madda is an unknown quantity at this point
Beautiful job, can't wait to see the final product!
Ari, when you make parts with your BF20l, what tolerances do you get usually on the parts?
