Old 07-23-2013, 01:24 PM
SmallHaul's Avatar
Default Light system options?
Maybe i just couldn't find it but, i didn't see a light kit thread...
i am overhauling another Wedico loader for someone and he would like a light kit installed so that it has brake lights and back up lights.
We tried the rc4wd/smart light kit and the headlights turn off when you back up and the tail lights go out when you forward...i.e. not good..
Any ideas for a nice light system?
Scott
"No load is too Small"
Old 07-23-2013, 03:15 PM
woodhog's Avatar
woodhog woodhog is offline
Default Re: Light system options?
I had emailed r/c lites once and they told me that they could configure one of their kits for a semi,so I would think that they could configure one for the loader. Sorry I done have a link but hope the info helps
Woodhog
Old 07-23-2013, 07:10 PM
SonoranWraith's Avatar
It's a dry 115 degrees.
Check CTI modules. AFV carries them.
Old 07-23-2013, 07:30 PM
SmallHaul's Avatar
Thanks Woodhog, i just looked at there web site and it looks like they might have what we need.
Thanks for the info SonoranWraith, It looks like the CTI stuff is good but, without clear english info on what each device can and can't do i wouldn't want to guess that i am ordering the right device, that does the right thing.
Scott
Old 07-23-2013, 09:19 PM
apfubar apfubar is offline
Ihave some experience wit the cti devices as they are in my excavator(lights) and in one of my trucks(controlling lights and relay for a pump motor).
They can have up to four outputs, each toggled on/off by a single channel.
Cheers,
AP
Old 07-24-2013, 12:35 AM
doodlebug's Avatar
Am I understanding, that they have Bruder conversion part's?
Cheer's, Neil.
Old 07-24-2013, 09:06 AM
SmallHaul's Avatar
Looking at all of these lighting systems i am surprised at how hard it is to find these options.
1)Headlights stay on
2)Taillights dim and bright when brake applied and turn off when reversing.
3) reverse light that comes on when backing up
i will call rc-lights and see if this unit does what we need for a loader:
http://www.rc-lights.com/products/RCL5053.html
Scott
Old 07-24-2013, 04:21 PM
Tp_hofmann Tp_hofmann is offline
Tp_hofmann is on a distinguished road
I changed the original wedico electronic to servonaut.
S20 with rear and brake lights in conjunction with a ml4 do the job now :-)
Br,
Tom
Old 07-29-2013, 12:41 AM
Sentinel's Avatar
Sentinel Sentinel is offline
Sentinel is on a distinguished road
Have a look at the HeyOk lighting controllers that RC4WD are now selling.
http://store.rc4wd.com/Brake-Reverse...er_p_3131.html
This particular one has several outputs, you can have an always on for headlights, a switched output for driving lights that comes on with forward throttle, the tail lights are dim while driving and are always bright for brake lights with the throttle in the neutral position, and with reverse throttle the reverse lights come on.
You could always just ditch the switched front output and you have always on headlights and tails, with switched brake and reverse.
They've recently started selling their products and they have a few different options for lighting modules.
Old 07-29-2013, 09:17 AM
SmallHaul's Avatar
Originally Posted by oztruck View Post
There is a small unit that also has sound that will do all of what you want + indicators and can be configured that when it is not moving the brake light stays on.
It is called a Turbo9
http://9rc.com/9turbo/index.php?main...&products_id=1
Cheers Chris
We are already using servonaut for sound but, that does look like an interesting option.
Br,
Tom
We are using SMX and already have all of the control functions mixed to control the sound. So, with your setup do you still have the beeper sound when backing up and do you have all of your stick movements mixed to sound? That would be great to have the back up beeper.
That looks like a nice system and it seems to do everything we need.
Scott
Old 07-29-2013, 09:23 AM
SmallHaul's Avatar
Originally Posted by lostinoz View Post
Hi Smallhual.
I have just ordered some of these from Hobbyking. I have no idea what there like but the price is good.
http://www.hobbyking.com/hobbyking/s...arch=led%20car
Regards Ralph
i didn't see how you program it but, the video they show just cycles through a bunch of "flashing" sequence choices. Not sure what the set up options are.
Scott
Old 07-29-2013, 12:43 PM
Pippoe Pippoe is offline
Pippoe is on a distinguished road
Hi,
I used this one on one of my builds (sorry.. the page is in German..). It's tiny, but works great:
brake/reverse-switch
They have a new model that includes a beeper now..
Beeper thingie
Here's the vid of it in my Jero:
(I used the reverse module in combination with this module here:
turn signals and lights
..this one switches turn signals and lights).
Cheers
Pip
Old 07-30-2013, 09:58 AM
SmallHaul's Avatar
Originally Posted by Pippoe View Post
Hi,
Beeper thingie
Cheers
Pip
That light system works great and your Pajero is very nice!
Scott
Old 07-30-2013, 05:09 PM
I dont use sound in the cat.smx&s20 can be combined and the rear beeper will work.
For the stick movements: do you refer to the valve movements ?
Br,
Tom
Old 07-30-2013, 07:04 PM
SmallHaul's Avatar
Br,
Tom
Tom,
i like to have all of the engine rev anytime work is done so, if i have enough mixes available i mix everything to command the sound.
i just overhauled this machine for someone and all i need to do is figure out which light system we are going with so that i can clean up the wiring.
http://www.youtube.com/watch?v=4fX5O2wond4
Scott
Old 07-31-2013, 04:52 PM
For the loader I recommend Servonaut S20 and ML4, in addittion to the SMX. Several guys use thet combo here in Norway and it will give you all the functions you're mentioning.
Old 07-31-2013, 08:52 PM
SmallHaul's Avatar
Thank you very much for this information. This is probably the route we will go then.
Scott
Old 08-18-2013, 05:12 AM
rson123 rson123 is offline
rson123 is on a distinguished road
Very nice, can you provide links to the site that sells them please?
Old 08-18-2013, 02:34 PM
Tom,
Scott, I don't think any operator, or 1:1 machine would be on the job very long, with direction changes taking place without idling the engine down first. It seems less realistic to me with the RPMs running up when cycling the hydraulics.
Old 08-18-2013, 09:32 PM
SmallHaul's Avatar
Nathan,
Here is a vid of a full scale 996G, turn up your speakers and notice how much it throttles up just turning:
https://www.youtube.com/watch?v=XtlYjiBTukw
and this how i set up an RC 996G:
https://www.youtube.com/watch?v=cmTSjSnnCAY
Much more realistic than just having the drive run the sound IMHO.
Scott
