Old 06-11-2013, 12:28 PM
Default Bruder Liebherr L574
Then tonight I'll show the conversion
Old 06-11-2013, 04:07 PM
Default Re: Bruder Liebherr L574
This is the conversion of a bruder liebherr l574 with hidraulic:
Old 06-11-2013, 04:47 PM
after disassembling the machine start with two servos modify 18 kg for traction wheel of the machine[IMG][/IMG]
you have to remove all the electronics and leave only the engine as well as remove caps to rotate 360 degrees
Here you can see the servo also used for the direction of the machine, I had to make a few pieces of aluminum to hold down the plastic besides the machine to fit the servos
for rear axle servo have to cut a chunk, so that it fits well and can swing the shaft
I have plastic lined to keep the putty from sticking to the servo
I bought a hydraulic kit for this machine with a 10 bar pump, a delivery hose and necessary as well as the hydraulic fluid tank, put more progress tomorrow
Old 06-11-2013, 05:04 PM
lee.means lee.means is offline
lee.means is on a distinguished road
where did u get the hydraulic kit from
Old 06-12-2013, 10:37 AM
Hi, from this page: http://www.magomhrc.com/es/
continued with the transformation
Here is presented the piston that lifts the bucket, And the three pistons placed:
here and I have mounted the pipe for hydraulic fluid
And that's all for now
Old 06-13-2013, 03:34 PM
continue with the transformation, I've placed the rest of the electronics, along with the deliverer and the tank valve, I've also the driver's seat upholstery, painted the details and we've made a fire extinguisher
I put a home video
http://www.youtube.com/watch?v=3Tm9dp9AuC8
I have not much use yet, but hey I need practice gradually
Old 06-13-2013, 07:21 PM
louie r/c nut louie r/c nut is offline
louie r/c nut is on a distinguished road
Cool vid That's one sweet rig wanna build me one .
Old 06-13-2013, 08:05 PM
Me too!
Old 06-14-2013, 03:43 AM
ngward79's Avatar
ngward79 ngward79 is offline
ngward79 is on a distinguished road
You guys may want to check this site . They have a lot of conversion parts for Bruder products.
http://www.rcteknikk.no/product_info...roducts_id=400
Hydraulic kit
Metal parts
Planetary axles
They also sell almost ready to run Bruder dozers , track loader and excavators too .
Old 06-14-2013, 06:59 AM
Great contribution my friend, i will look later on this page some interesting pieces for my Liebherr
Old 06-14-2013, 07:03 AM
page in Spanish that I discuss the prices are cheaper than in the other, the only thing there pieces such as the bucket or arms of the machine
Old 11-11-2013, 11:23 AM
cosworth34677's Avatar
hey how did you glue the shaft to the servo outlet?
Old 11-11-2013, 04:29 PM
ngward79's Avatar
Found this just the other day if anyone is interested. Think I may have to build one of these soon.
http://www.afv-model.com/4711shop/pr...oducts_id=3580
Old 11-11-2013, 08:04 PM
Ashrod Ashrod is offline
Ashrod is on a distinguished road
What are you using to control the hydraulic valve??? I think I might order one of the kits for my loader!!! I assume you are using 2 servos to do it, but I am not sure on size and how you connected them to the valves!!! Thanks
Old 11-11-2013, 08:27 PM
its the mangon hrc kit very ggod stuff and good price, they use three small sub micro servo's like the little 9g servos or the hi tec hs-55
Old 11-11-2013, 09:46 PM
Do you have to buy them separate and install them on the valve body yourself???
Old 11-12-2013, 07:05 AM
you have to buy them separate. but if you buy them from there site they will putt them in for you .
Old 11-12-2013, 09:30 AM
Cool, thanks a bunch for the info!!!
