#401
Looks like it's going to shape up to a really great looking dump. Got me thinking I may have to start dabbling in dump trucks! Keep up the great work.
Look'n neat with no air in the seat |
#402
Looks good Mario..
![]() ![]() Wayne |
#403
Great job Mario. This will be a really good add-on for the dump boxes I am building. I hope this project is as much fun for you as it is for me! Keep up the great work!
#404
Great job with everything bud. Love the Pete!
#405
![]() ![]() Thanks Wayne. I cant wait till basement renos are done and building can get up to speed! Quote:
Hows about a service truck body perhaps? I have zero experience with styrene and you are a master of metal so....![]() ![]() ![]() thanks Brian. The Pete is definitely my crown jewel build.......For now! ![]() ![]() Small update on the dump truck. Staying with the work truck theme instead of show stopper. Im trying the look of some black light bezels from Russ for this build and had a chance to check out the look on the truck. I love them! . installed on the tail plate they look like the rubber mounted lights on a work truck. Planning on installing some on the box side corners also. ![]() ![]() ![]() ![]() ![]() ![]() Thanks for looking. Comments, suggestions and ideas always welcome! ![]() Mario |
#406
Looks great! What are ur plans for stacks?
#407
Looking Mario, very nice work.
#408
Nice job on the lights in the bumper!
Service truck??? You already know I'm in ![]() ! Maybe we can build two! I have a fleet of equipment with no mechanic....
#409
**** Mario you got a serious building shop/man cave. I'm jealous bud. I can't wait to have a place to buold like that.
#410
Dump truck looks good, coming along.. Even a work truck can some bling...
Wayne |
#411
Thanks. I'm going to use the stock stacks with PMD turnout ends as shown in post #425. Once I get the cab mounted I will trim them down and will be a lot shorter.
Thanks Keith. I just realized my biggest hurdle is going to be the paint job! It's the middle of winter, don't want to paint in the basement and no heat in the garage I might try it at work but the air is so filthy there I know it will be almost impossible to have dust free![]() Quote:
![]() Glad to hear you like the service truck idea no rush though. I have an entire backyard that needs a Rc makeover this spring so, funds go there first!Quote:
![]() ![]() ![]() ![]() I liked my old set up but having a space in the house is great! Quote:
![]() Mario |
#412
I would hold off on paint till spring when you can get it the way you want it without having do redo it... hate to see you get a aggravated at it cause of a run or something... looks good the way it is so I'd say it can wait a little longer. .
build is looking great!
#413
Yeah, I agree with Aaron. There is nothing worse than shooting the paint just to get it done and then not be happy with it, I've got three cabs right now that I just stripped and are on deck waiting to painted again.
Truck is looking great, gonna be a nice addition to S&M trucking. |
#414
![]() Heck, it might take me till then just to figure out how to make everything fit inside the cab! The plan is rather than fill the opening in the back of the cab with styrene, I want to mount a aluminum plate ( anchored to the cab floor plate, not the cab ) The rookie window will actually be where the rectangle speaker I have mounts and hoping enough room below for the 2 ESC 's . Servonaut sound board under the hood....now just gotta fit the battery, receiver and light module ![]()
#415
What tanks you gonna run? just an idea BUT even if you get custom tanks from like Russ or Steve have them not glue the caps on drill 2 holes on back side twards frame. Find 2 smaller 1600 MAH batteries then cut plugs off, send wires thru holes then up to the cab where they connect together to make 1 3200mah battery that has a switch... then go even farther do like I did on the globe get 3 position switch battery in middle charge lead on one side and truck power on other side... flip right (or left) and bypass truck and just charge batteries, flip other way and drive away. it'll save you some room in that cab.. Just an idea.
you could even put esc or receiver in your step boxes depending on which ones you use too. if you look at the blue dump travis used aeromax tanks I think maybe they are knight hauler and glued the batteries under it.
#416
I was planning on using the stock tanks but now that you mention it, that's a great idea for freeing up some cab space. The ESC's are small. ( same as the ones in my loader as a matter of fact ) I think it would be money well spent to buy some custom tanks. Thanks!
![]() I'm on the rc4wd site right now. Going to pull the trigger and order this light system. It's small and has some decent options and cheap to buy. http://store.rc4wd.com/Auto-Hazard-L...er_p_3132.html I think the charge port is a great idea to minimize opening the truck all the time but when you want to play for more than a charge cycle it's nice to throw a fresh one in, throw the old on charge and keep on trucking! |
#417
See that's what nice about having more then one truck. When one goes on the charge the other gets driven. You could do stock tanks like i have on the blue dump just put quick connect on batteries and use velcro instead of double sided tape. This way you could still swap out for fresh batteries if need be?
#418
This thing may be a better alternative to RC4WD's one
http://www.bel-shop.eu/en-detail-110...stem-dss2.html It provides turn signals, breake light, front light, beacons... Only con is, that I'm not sure about the shipping costs... |
#419
Thanks for the link. that does have everything I want. I already placed the order from RC4WD but if I don't like or get tired of it I can try this one. Thanks again.
![]() Small update on my crappy dump truck build compared to some of the great ones being built right now if it wasn't for Reg's box I probably wouldn't even post it![]() ![]() ![]() had an idea for the aluminum back cab plate im using. it will be secured to the floor and not the cab so i thought of doing this.... ![]() ![]() ![]() looks like i also have enough room for power and light switches. thanks for looking.
#420
Whoa Mario! Just crawled out from under my rock and checked your thread, that dump truck is going to be beautiful! Love that style of dump box, not the big coal style but more the rock bed. Excellent.
| Currently Active Users Viewing This Thread: 34 (0 members and 34 guests) | |
