Old 01-11-2014, 03:32 AM
Lmackattack's Avatar
Default Re: Mack R model ten wheeler dump
Still working on it but made a lot of progress this week...
I started on the dump box this week, its u shaped aluminum wall and floor Im using styreen for the side detail,door and bulkhead. A roof gaurd will be made after i know where the exhause stack will locate.Side boards will locate on top of the walls and a small spread pan at the rear. I used spring shackles to mount the box to the rear of the frame rails.
The bed sits on its own 20mm tall aluminum rails and will give proper clearancefor the rear axels
The lift tested good nd you can see the box has plenty of angle. I will be crossing my fingers it will lift a full load of dirt? If not i may have to revisit the lift as i still dont like how all the levrage is lost due to how far back the lift unit installs. I can't move it forward as it will interfear with the forward tandem. The drive has a u joint and the Carson lift motor is solid mounted in the truck frame rails.
I fabricated a box that will hold the battery over the motor/transmission. It's held to the frame with 4 screws so I still have easy access to the motor. A few rubber bands will keep the battery held down tight to the box
This will leave the floor space for the reciver and esc. I want as much weight over the steer axel to help with steering when its hauling a load. The cab will tilt from the front up and out of the way for access to changing the battery or electronics adjustment.
I made a cab visor and started fitting a air cleaner. The battery boxes are made and just need to mount them next to the fuel tanks.
I also got my driveshaft support bearing in and was able to test the rolling chassi for the first time.
Thanks for looking
Old 01-11-2014, 03:45 AM
ratsrail's Avatar
ratsrail ratsrail is offline
ratsrail is on a distinguished road
where did you get the r model cab and hood from ? i would so love to find one
Old 01-11-2014, 03:49 AM
Bought it from a guy selling stuff on eBay...I think it is made by the 3d printing company shapeways....there is a guy on this site that sells the same r model cab and hood and i think it's also made by shapeways? He has a superliner as well.
Old 01-11-2014, 10:28 AM
Grainfarmer Grainfarmer is offline
Grainfarmer is on a distinguished road
Very nice! That dumper looks great...
regards
Frank
regards,
Frank
Old 01-11-2014, 10:43 AM
BRICKNICK's Avatar
BRICKNICK BRICKNICK is offline
BRICKNICK is on a distinguished road
Sick looking mack buddy. I'm really digging this build. It's nice to see a new cab/fresh face being built. Any ideas on a paint scheme yet?
Old 01-11-2014, 11:31 AM
Still up in the air...being that it's modeled as a late 60's early 70's R model I'm thinking basic paint nothing flashy dark green hood and cab with a Black or dark gray box... I was also thinking of doing a long time east coast tradition of green and red...kinda like this pic.
Old 01-11-2014, 11:33 AM
I really like your project, I have a question: cab've made ​​yourself?
Old 01-11-2014, 11:49 AM
I believe this cab and hood was 3d printed by shapeways.
Old 01-11-2014, 12:25 PM
dabears's Avatar
dabears dabears is offline
About time theres an update!!! Looks good! I'm liking it!
question- I like how the box has a nice angle but im worried it may not lift loaded being so far back? that's a lot of overhanging weight. just a thought as I was looking at it.
Hit me up next time you roll thru Pheonix too on your way to Cali
Old 01-11-2014, 04:03 PM
Yea. Lifting force, It's got me worried too...this lift just won't fit in the frame right without it interfering with the tandems or inter axel driveshaft. If I place it forward of the first tandem it only raises the box half as much. So I'm already looking into a screw drive like your trailer had...
Old 01-11-2014, 06:35 PM
dabears's Avatar
ok so not knowing anything about the scissor lift style what if not sure itll work but push the lift twards the front and make longer arms off the triangle piece? would that work? like I said im not sure on how all the parts move exactly as I havnt played with one yet but depending on how it all folds up can you make the arms longer? and maybe more twards the front or past the middle a little?
Old 01-12-2014, 01:31 AM
wolfws6's Avatar
wolfws6 wolfws6 is offline
wolfws6 is on a distinguished road
That sure is a nice looking Mack!!!
Old 01-12-2014, 01:42 AM
I took the lift out tonight and tried a few things and I still can't get it further forward. I think longer arms may help but how this thing is designed I can't move the mounting of the lift any further forward. So even with longer arms it still will be pivoting in the same spot, thus longer arms will decrease leverage..... I will just have to test it out soon..
So after all that I kept working on the cab and box....I mounted the battery boxes,stack and trimmed the roof for cab lights. My next issue will be a front bumper...I'm going with the look of a steel bumper I started with plastic but I think I want to put a nice pice of steel up front I case I run into something... These old Mack's were bullet proof so I'm going to keep it in true form.
I test fitted the air cleaner and mounted the dog on the hood...after I get everything fitted I will think about paint...
Im not sure I like the budd rims on this truck. I was looking at spoke rims on eBay but they were the same ones as rc4wd sell and in my opinion don't look good...has anyone made good looking spokes wheels?
Old 01-12-2014, 01:47 AM
dabears's Avatar
you know that lift might just work the way you have it. do you have room to add a cross member at the very front of the lift rails? tust to box it in so there is no twist? if you can do that I think it might be ok. all the euro guys use this setup and every one ive looked at is mounted in the same spot.
Old 01-12-2014, 01:59 AM
Yes, It has plenty of space for crossmembers up front...however Right now it has no twist at all. The box rails are solid 20mm tall and the floor and walls are formed from single sheet of .080 aluminum bent to form a box... I kinda over Built it and that's not helping the lift unit with the extra weight...
Old 01-12-2014, 02:31 AM
wolfws6's Avatar
For the wheels, contact IH Steve!!!!!!!!!!!!
Old 01-12-2014, 03:45 PM
crawler07 crawler07 is offline
crawler07 is on a distinguished road
Great looking truck! Im with ya on the green and red I think that would look most fitting. Also a little weathering and this thing would be out of this world. One suggestion and maybe your already going to do it, but it might look more like the 1:1 if you move the dump box back from the cab a bit?
Old 01-12-2014, 04:15 PM
MACK Daddy's Avatar
MACK Daddy MACK Daddy is offline
MACK Daddy is an unknown quantity at this point
I love That!
Alfy
Always Wheeling, Always Dealing !
Old 01-13-2014, 11:39 PM
Here is a quick video of the dump set up i used a tamiya esc for operating the dump bed.
..https://m.youtube.com/watch?v=zHxKNvnE-BI
The ground is frozen here so I went outside and loaded it up with a full load of salt....I was surprised that it lifted it as easy as it did....I might be ok with the set up...
Old 01-13-2014, 11:58 PM
dabears's Avatar
box is lifting great! maybe that setup will work fine!
