Old 11-08-2010, 02:33 PM
firefighter30's Avatar
firefighter30 firefighter30 is offline
firefighter30 is on a distinguished road
Default Re: Bruder Delta tracked loader
Scott, nice job on the Loader looks great and seems to have a lot of power. seemed to work really well in the video.
Doug
Member of the East Coast Mini Truckers
Old 11-08-2010, 06:15 PM
SmallHaul's Avatar
Originally Posted by tc1cat View Post
Nice conversion I still don't see how you guys get all of the necessary components inside one of these little vehicles
Thanks! It just takes a lot of patience
Lynn
Thanks Doug!
Scott
"No load is too Small"
Old 11-09-2010, 10:19 AM
Well done! And thanks for listing the parts used. Helps for those of us not experienced with RC components.
Old 11-09-2010, 11:14 AM
dirtpusher9's Avatar
Moderator
Another find job Scott, that thing is bad too the bone for a little guy.
Old 11-09-2010, 10:51 PM
SmallHaul's Avatar
Thanks! You are welcome, the sabertooth esc is so smooth.
Thanks Joe!
I charged a 7.2v (6 cell nimh) 1500mah losi mini-t battery and ran it for over an hour today to see how much power it uses and it was still going strong. So, I don't really know how long one charge will last but I would say it is efficient.
Scott
Old 11-10-2010, 03:43 AM
aseejr aseejr is offline
aseejr is on a distinguished road
Awesome build. Can't wait.....
Old 11-13-2010, 10:42 AM
Mustang Mustang is offline
Mustang is on a distinguished road
Great build! Thanks for showing what motors you used with the Tamiya gearbox. I've been stuck on my Bruder conversion looking for replacements for the stock Tamiya ones. Looked at everything except slotcars - DOH!
Old 11-13-2010, 11:29 AM
Nice build Scott! You should have built two or three in the process so you can keep one. You still should let Scotty up here try to break it
Old 11-13-2010, 02:01 PM
SmallHaul's Avatar
Thanks and you are welcome. Professor motor online store has good prices on there motors.
Thanks Steve! I am in the process of building 2 more right now that are already sold and I might just keep the first one I built for myself. York should be a blast, I can't wait.
Scott
Old 11-13-2010, 06:50 PM
Snochaser's Avatar
Scott, that's really nice. I believe I would like one of those! Just something else on the list now.
-Ben
Old 11-13-2010, 10:07 PM
J Hall J Hall is offline
J Hall is on a distinguished road
Well done...I admire you guys that can make models that small work... Any thing smaller than about 1/8 scale is too small for me...
Old 11-14-2010, 08:48 AM
SmallHaul's Avatar
-Ben
Thanks Ben.
Thank you very much. I really enjoy the engineering challenge of getting strength & power out of these little machines.
I improved the bucket curl mounts. The mounts on the prototype loader work fine but, they don't like nice.
This design has more rigidity and protects the servos from getting hit:
With the servo screw heads milled down it allows the two servos (sitting back to back) to fit nicely in the lift assembly and creates a rigid assembly.
I also made beefier aluminum drive hubs. I'll post up pics later when I get the 4-40 screws that I ordered for them.
Scott
Old 11-14-2010, 09:00 AM
SmallHaul's Avatar
Forgot the side view.
Scott
Old 11-14-2010, 10:01 AM
Trixx Trixx is offline
Trixx is on a distinguished road
Looks great.
i want to build one to
Old 11-14-2010, 10:25 AM
JAMMER JAMMER is offline
Thumbs up Re: Bruder Delta tracked loader
Hey Scott nice work and boy is that thing fast. It just about the right size for your Tonka truck. Ed
Old 11-14-2010, 04:37 PM
SmallHaul's Avatar
Originally Posted by Trixx View Post
Looks great.
Thanks
Thanks Ed! Yes, it loads the Tonka fast. It'll probably load the Mack DT fast too but, I'll need like a 2" or so tall ramp to load it.
Another photo of the new bucket curl mounts. If you look closely you will see a small kick plate between the servo and the hoop mount. It locks the bottom of the servos tight against the bottom plate.
Scott
Old 11-14-2010, 05:00 PM
chaseracer's Avatar
another great conversion Scott, super work as always, and thanks for all the great pic on how you make these work. I am sure is a big help for alott of us thinking of doing one.
Old 11-14-2010, 06:24 PM
td9clyde td9clyde is offline
Dozer Builder
yep the machines you build are awsome i wouldn't have thought of useing servos for drives or putting in the twin gear drive box very nice work
Old 11-14-2010, 07:30 PM
W900snowman W900snowman is offline
W900snowman is on a distinguished road
Scott, thanks for the awesome photos and for posting a parts list. It's a big help and very informative.
Old 11-14-2010, 08:39 PM
SmallHaul's Avatar
Thank You very much. I tested, repaired & installed automated vehicles for many years. So, it gave me a good feel for hydraulics, screw drives & servo motors.
You are welcome.
Since I had to order more parts, I have a more accurate list:
Radio system
Tamiya twin motor gearbox
shims for tamiya gearbox assembly (you loose about 10 to 20% of gear contact on some of them if you leave them sloppy)
silicone to seal gearbox up (makes it last a very long time)
2 x slotcar motors (tamiya motors are 3.5 volts and fry quickly)
Aluminum stock to make drive hubs
4-40 screws & washers to secure gearbox to chassis
Saber tooth motor controller
5 volt 5 amp (continuous) bec
Hitec Digital HS-7955 TG lift servo
2 x hitec hs-5065mg digital servos for bucket curl
Hitec servo programmer
3" Y harness to join the 2 bucket curl servos
2 x 12" male servo leads to extend the bucket curl servos
heat shrink for all of the bucket curl servo wiring
piece of bicycle inner tube for lift lever cover (need to post pics)
4-40 rod and clevis for lift lever
lead weight
and 1 boat load of patience
Scott
Currently Active Users Viewing This Thread: 522 (0 members and 522 guests)
