Go Back   RC Truck and Construction > RC Truck's Kings of the Road > Australian Rigs & Roadtrains
Australian Rigs & Roadtrains A place for aussies to show off their unique truck configurations.
Old 11-13-2014, 07:30 AM
PaulNZ's Avatar
PaulNZ PaulNZ is offline
Default Re: Freightliner Logger - Built By PaulNZ
Thanks for the kind words guys
What is a big load for these trucks? 20KG 30KG?
I think if I fill the bolsters it will be @ 20KG payload, is this too much? am I pushing it?
The trees I'm using have been a really good find, they are young hoop pine that are very straight and don't have too many Branch's, and the best thing is that they are in a housing Development so they are getting cleared and I don't feel guilty about cutting down young trees
I think I will add another 4 pieces to finish it off
cheers
Paul
Old 11-13-2014, 09:27 AM
up9018 up9018 is offline
Paul,
Great looking truck. The details you made for it came out superb, very nice work.
If you are worried about the weight of your log load, then might I suggest making them out of foam. This is a popular construction method among G-Scale railroaders to keep weight down. You just need to go to your local building supply store and pick up a piece of 1-1/2" - 2" thick Pink (or Blue) foam. Use the solid kind, not the white beads type. Then you simply cut a block to the length you want and start carving. I have found a stiff wire brush will make quick work of the foam, and leave you with a bark appearance. (It makes a big mess so don't do it in the living room) A little detail work to the end and then paint with a craft paint. Make sure you vary the length and diameter of your logs, but don't change the outer appearance, you want them to look as they came from the same place. Once finished use a little white glue to turn them into a bundle and wrap a chain around them in a couple of places. Then you have a nice full yet light load for your truck.
One other benefit to this method is they will last longer and be less likely to attract bugs than real wood.
Old 11-13-2014, 05:54 PM
PaulNZ's Avatar
Hi Chris
thanks for the info but I would rather make it work hard with a real load and build it take it, just need to know what the trucks are capable of as I don't want to break it either
cheers
Paul
Old 11-13-2014, 08:00 PM
TRUCKMAKER's Avatar
Paul, if my conversion is correct 30KG is about 66 lbs, I've seen a tri-axle king haul about 80 lbs on flat carpet floor. So I'd start around 20KG and see how it goes. If it does not strain much and preforms well add some more.
Old 11-14-2014, 09:52 AM
kaptain Jack's Avatar
Paul,don't worry about load,look at my granddaughter taking a ride in the video section of this forum.
http://www.rctruckandconstruction.co...ead.php?t=9662
Old 11-14-2014, 12:40 PM
A littlebit depending on the surface, 20 - 30 kg should not be a problem. Locked diffs on a high friction surface may cause some wear and tear, but the Tamiya axles are extremly tough.
Old 11-14-2014, 05:00 PM
PaulNZ's Avatar
Nice!
Thanks guys, I think I'm looking at between 20-30 kg so it should be ok, just need to get my Hp and gearing sorted
Cheers
Paul
Old 11-17-2014, 12:24 AM
My first time visiting this section of the forum, ive been missing alot !
Thats a great looking truck and as Reg stated, your logs look incredibly scale. Overall one the cleanest looking trucks ive seen.
Old 11-17-2014, 02:19 AM
PaulNZ's Avatar
Cheers! means a lot
got the sound unit for it today so once I get that installed and a couple of minor things done, I can call it done, I will then uploads a video and post the link
thanks for looking and again thanks to all the kind words from everyone.
Paul
Old 11-17-2014, 02:34 AM
Cossett's Avatar
Cossett Cossett is offline
On Leave
Hi paul what sound unit are you using in the daycab, i saw one for €110.00 from http://www.rcbrmin.com/114-rc-truck-...-l6-p-535.html but it looks like there is no reverse sound on it ?
Cheers tracy
Love my Kenworths
Old 11-17-2014, 09:06 AM
PaulNZ's Avatar
Hi Tracy
looks similar but I have just one speaker, I went for this as it's small, may not have all the functions of some others but it will be ok, Loggers don't have reverse buzzers anyway, if they are backing up you best move out of the way, I've spent many a time getting off a forest road to make way for log trucks, they don't stop and wait for you
Old 12-05-2014, 03:24 AM
PaulNZ's Avatar
Update:
Truck is finished......till I change something else
I have installed a 60T motor and it has a lot more power than the 80T so lesson learnt on that one.
open heart surgery, looks like a real truck getting a motor swap with all the electronics under the hood
I will post a couple of final pictures and a video tomorrow
Thanks for all the positive comments, I've enjoyed this first build and dare I say it.....wont be the last
Cheers
Paul
PKD Scale Engineering.
Old 12-06-2014, 03:48 AM
PaulNZ's Avatar
Hi All
just a couple of short video's
need to get a few better ones latter, I have also just got a small video camera that I will clip to the headache rack and get a driving one once I get a micro sd card for it.
http://youtu.be/wTd2Mirpxyo
http://youtu.be/UFiceMapEbM
Old 12-06-2014, 07:58 PM
crisis time's Avatar
crisis time crisis time is offline
crisis time is on a distinguished road
Looks great Paul
the logs look great for scale
Old 12-06-2014, 10:36 PM
flatdeck's Avatar
flatdeck flatdeck is offline
Paul that is a great looking truck.. looking forward to your next build....
Wayne
Old 12-07-2014, 07:22 AM
PaulNZ's Avatar
Originally Posted by crisis time View Post
Looks great Paul
Logs look great but they are heavy at 30KG!!! truck works hard to haul them but it handles it except I don't get much run time as it draws so much from my battery, and as Maverick has pointed out I don't think my charger is the best so I've ordered a new digital one.
Wayne
There is a big present under the Christmas tree, wonder what that could be
Thanks for the kind words Guys, I will try and find a bit of time over the next few weeks to get some decent video footage done, maybe on a forest track, we are not far from a Pine plantation........
Cheers
Paul
Old 12-07-2014, 10:54 PM
Paul, nice videos, your truck came out great! You need to build an Elphinstone EasyLoader for your next rig. Would love to see what you would come up with.
Old 07-27-2015, 04:47 PM
PACT PACT is offline
PACT is on a distinguished road
Very nice build looking sharp!
HHA Knight Hauler owner
Sry for my bad Eng, Im a Viking!
Old 11-30-2016, 05:33 PM
neil burritt neil burritt is offline
neil burritt is on a distinguished road
how much for cab guard shipped to bc canada
Old 11-08-2017, 08:30 PM
Would you consider making cab guard, bunk gear, AND that trailer for sale? I'll be working on a logging truck this winter, & really like what you've done. Since I DON'T have access to CNC, only basic hand tools, my fab capabilities are very limited to what I can accomplish.
