Old 11-07-2010, 09:16 PM
Default Re: dresser TD40B dozer
Clyde I just hit it with a quick coat for pics. I hope to blast and paint when done .
Old 11-07-2010, 09:26 PM
td9clyde td9clyde is offline
Dozer Builder
ahh thats a good idea then you don't have to fight the rust like i do lol
Old 11-10-2010, 11:13 PM
yea I learned that the hard way
I'm thinking of leaving the tracks wide instead of cutting the 1/2" off to bring to scale width . Kinda looks like a wide track . I'm going with the single motor drive , just to see if it is possible in RC . I got pretty much figured out , just the time and parts
and a quick peek of this
I still have to machine the shaft and bolt together to test flow and pressure . only non calculated variable is the motor ( not sure if it has what I need ) but we'll see this is just a trial to see if I can make a pump from the scrap pile
Old 11-11-2010, 08:24 PM
dirtpusher9's Avatar
Moderator
I'm glad your going with one motor and steering clutches, you can be the guinea pig to see if works.lol Any more progress on the pump?
Old 11-11-2010, 09:34 PM
yes I actually put it together and tried it , have some seal reworking to do . It leaked between pump and motor . Yes ,I'll be the guinea pig on this 1 ,and will not give up till it works . need less to say nothing will be running anytime soon , lot of small parts to make . I need to get some chunks of aluminum to make 4 trannies for the scrapers , 2 reversers for this , valves , and pumps . if the vain is a no go then back to the gears .
Old 11-14-2010, 10:22 PM
well I got my pump working still got to get a shaft seal , A quad ring just not going to cut it ( should've known better ) . now on to the next unaffordable part valves . I think I'm going to wear this taig mill out with these 3 machines
IHSteve
Old 11-16-2010, 03:32 PM
Vanisle Vanisle is offline
Nice work on the pump - a vane pump you say. Wow, nice work. Would a press fit bronze SAE863 collar on the shaft help seal it? Are you planning to make the valves? If so, are you going to do a closed or open hydraulic system?
Old 11-16-2010, 04:15 PM
SmallHaul's Avatar
Nice progress Steve. Pump looks good!
Those HD brand servos I told you about on the phone don't like to sit for a long time under load, they have so much holding strength that they burn up from heat. So, they probably would be good to move/hold valves.
Scott
"No load is too Small"
Old 11-16-2010, 06:10 PM
I'm might try something off the shelf first . not sure yet on open or closed . as for seal , I just used what I had laying around to try it out .
thanks Scott , any servo holding a load for a long period of time is not good for it , I would think . I'll cross that 1 when I can get to it .
Old 11-16-2010, 06:42 PM
Losiassociated
Guest
Posts: n/a
Steve,
looking good man i must say u r crazzzyyy!!!!!!!!!
LOL
Old 11-16-2010, 07:38 PM
Originally Posted by Losiassociated View Post
Steve,
LOL
AAAAANNNNNDDDD getting worse
thank you Greg
Old 11-22-2010, 09:24 PM
Moderator
Any progress Steve?
Old 11-22-2010, 09:50 PM
woodhog's Avatar
woodhog woodhog is offline
dozier lookin good keep on fabbin
Old 11-22-2010, 10:23 PM
Any progress Steve?
only a little , Joe , welded up 1 track frame tonight had to get 68 steel wheels to the powder coater now got to finish the hubs for them and the next batch . my rollers will be hard ( cummins cam followers ) ? for you did you use bearings in yours or just a brass bushing ? I was thinking sealed bearings but may go with oil lite bushings and looks like the $ is keeping me on the make it my self path for awhile . got the shaft seal for the pump just didn't get it in yet .
thanks , Oh I will lots more to build
Old 11-22-2010, 10:29 PM
Moderator
I used oiled bushings, no wear yet.
Old 11-22-2010, 10:37 PM
yea I'm leaning more toward them It's not like the full size where it take a couple hrs to change 1 .
Old 11-22-2010, 11:18 PM
Dozer Builder
well we need pics!!!!!!!!!!!! lol i am wanting to see if the one motor and planitarys on the outside is going to work I hope it does cuz i have a few ideas
Old 11-23-2010, 12:07 AM
you'll need a lot of this
Old 11-26-2010, 07:46 PM
here you go Henry not much
Old 11-26-2010, 08:45 PM
Dozer Builder
Nice work rollers take forever to make lol
