#481
I was going to suggest that...
![]() Here's a machinery trailer that's simpler & quicker use than a scissor neck. ![]() https://www.youtube.com/watch?v=h3FDPryPhwo
#482
Hey joe I got the printer back up and running,
I like the sliding axle trailer. With the parts I have I figured a folding gooseneck is doable. The parts on my shelf need a home . I'm going to try and use the firgilli actuators and full size tires I have. After mocking some parts up I may still have to have a little bit of drop for the back wheels. Am trying to avoid purchasing smaller wheels. Kind of a home inventory build I guess. At least that's how most of them start right? Lol!!! I have been using dry graphite on the dozer, clings to aluminum well and cheep. The stuff I have is in a bucket and just brush on. Dirty but effective ![]() I have a mini-barn delivery guy that has one heck of trailer, extends an extra 20', can rotate the barn 360 degrees, dovetail moves left/right, has drop wheels to lift and move complete trailer left/right, rollers, winch, all the bells and the remote controller is close to the size of a bigger cell phone!!! Next time I see him I'll get a pic
#483
![]() Boy reg I could really use your expertise in welding some alum!!! I may try and set up the mig for aluminum. Never done that, I just need to get a bottle of gas. I think all the welds I would need to do will be hidden . I could make it out of sheet steel but think that may lend to be on the heavy side? And I'm pretty sure I'm going to have to make it a drop deck with the wheels I'm using. I think I remember somewhere you guys moving the fifth wheel up to get more weight on the front. How far do you guys move it? 1/4"? The truck is using stock tranny but high turn motor. It would be nice if I can haul the excavator less than 60# if I remember. But before I get too involved with this I am going to see if the configuration I'm thinking of with the actuators I want to make sure they will lift it. (Instead of the usual build it and then find out )
#484
I think the trailer will look awesome, especially if you get the actuators working and dialed in. As far as pulling weight, even though you have a higher turn motor i would highly recommend a gear reduction, easiest to use at this point so you dont have to modify much would be the one rick sells at garden. Its on the pricey side but well worth the money by far. I can stand on a trailer and my Ct 660 will pull me with no problem or hesitation, so moving an excavator or any other machine you put on it should not be a problem. Good luck and keep the pics coming!
#485
Looks like a great start! I like it with the full size wheels. Certainly more typical of what you see here on the island anyway. I am no welding expert that's for sure. I have only tried MIG welding aluminum once with a spool gun so I can't give much advice there. Aluminum is fussy so make sure you remove any anodizing, paint or mess from your material before welding or the weld will be porous, weak and ugly. I agree with Brian that you need a gear reduction of some sort. I don't see you having any problem making your own though if you want to spend some time and save some money.
#486
Hey
I like your project. and yes i agree it,s hard to weld aluminum. However there is some other things out there that might work. Look at this. http://muggyweld.com/aluminum-to-brass-solder I am going to try this out soon. |
#487
I'm still in the concept phase, I bent some 22 gauge steel up to make some I-beams. With some well placed supports and gussets it might not be that heavy with steel. Would save a lot of work for me. Again still not sure what direction I'm going. I have been wanting to get some of that muggy weld.
I had to break out the super design tools,,, ![]() ![]() LEGGOS!!!! still play with em!!!!
#488
Greate work cooper and I am sure you will be happy with what you end up with and yes I still play with Lego's. Travis
AKA "00" Biddle RIP FreddyGearDrive 2-12-59/12-19-11 |
#489
Woodhog |
#490
Lol, my wife would harass me for getting Legos!! Every year we have a meeting in Orlando, basically stay at downtown Disney where a legoland store is. Gives me some away from home building to do!! Use to build them and give to nephews once home. But now they don't play with Legos so I've kept them for myself
. I made some pieces of I-beam from 22 guage steel. Put a little camber in them, love to see trailers with camber in. For just tacking together they are stronger than I thought and light too. So I may go the steel build. Basically a steel skeleton with wood decking. Gonna try and make it able to handle 60#. ![]() ![]() The pics don't show it well but from side it's rather a smooth curve.
#491
Perfect touch on the camber arch, what were you thinking of doing for suspension?
#492
Very nice. I'll be watching this one. Are you still going to the folding neck? Either way this will be a nice addition to you impressive collection of construction equipment.
#493
I was originally looking for your bi-fold beavertail trailer (I think it was you that did this), but you must have put that on photobucket video, eh?
#494
Looking around I figured a mock air ride suspension would work best. It's the simplest and gives me the most room for clearance and size of frame.
#495
Joe I do like the sliding axle trailer and great build on that one!! Thanks for sharing ![]() Made the outer beams today and some cross members. So far I'm planning on housing battery and electronics above the rear axles. Long wire run for servos (actuators) but takes a touch weight off front.
#496
Looking sweat! I like the folding neck. A few of the off-highway lowbeds around here are that style.
#497
I used them in the U S Military. http://olive-drab.com/images/id_m870_trailer_03_700.jpg No hydraulics, just a winch on the tractor, and no landing legs.
Cheers, Neil. |
#498
![]() Some more work in progress pics ![]() ![]() ![]() ![]() ![]() ![]() I'm slowly getting better at welding this thin stuff, but it's getting decking so they aren't going to be seen, as long as I don't flip it over
#499
Depending on how many channels your transmitter has, just throw another receiver back there in the trailer and plug into the channels you're not using on the tractor. You can link as many receivers to a transmitter as you want in parallel. If you want two dump boxes to go up together just plug the ESC into the same port on both receivers and they'll both work together! Also you'll have to get a BEC to power up the receiver back in the trailer unless you have an ESC for a screw drive or something else
Rob |
#500
![]() ![]() ![]() Blasted and ground, need a bigger blast cabinet!! If I make the wheel frame I doesn't fit in cabinet . And starting to figure out a spring (air bag) suspension set up. The arms may be short but it's what alumninum stock I had.
| Currently Active Users Viewing This Thread: 39 (0 members and 39 guests) | |
