#41
Okay, I feel a little dumb, I traded out the mounting screws with some button heads. held the screw head with my fingertip and spun the headlights until they tighten down on the screw. No tools needed in that space.
#42
Good looking Grille .......I want one......You could change screw to hex. and cut the tool to fit....just my 2c
#43
Very nice!
#44
Thanks Brandon! I've gotten a few more parts in, I will have to get an update one of these days.
#46
claus
did they come with the led? the super bright look great |
#47
The grille came with the headlight lenses but no LEDs.
#48
Just a small sneak peek of of a few things to come;
![]() ![]() ![]() ![]() ![]() ![]() ![]() Also waiting on a 60" Peterbilt sleeper from Goose and some other miscellaneous parts. Thanks for looking. |
#49
That is one nice truck, love the grill and light system on it.
Jim |
#50
Looking good Craig!
#51
Thanks Brandon, I'll send you my parts, you can polish them up! |
#52
#53
Did you get your front wheels sorted ?
Cheers Tracy
RIP FreddyGearDrive 2-12-59/12-19-11 Love my Kenworths To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#54
I loved the Wedico, looks awesome! I have 2 wedico Peterbilt sitting on my shelf as well
![]() the new built is one nice truck too! |
#55
Well, kind of. Parts on the way, will see when they get here. The AWD adapter and the black hubs I have do not go together.
Thank you very much! That one was a challenge. |
#56
Not sure about the lug nuts yet.
#57
Next step is to move my axle forward.
#58
1/4" with that hood. ♡♡♡♡ THAT 359
#59
Still unsure if I'm going to be using a Tamiya, Shapeways or Wedico cab I have not bought any of them yet. I was trying to do some test fitting without out a cab which makes no sense at all but anyways... I moved my front axle one mounting hole in the spring pack and set the hood over the wheels. I mounted a stock Tamiya floorboard in the stock location. The hood is up against the floorboard and the grille is just slightly in front of the bumper mount. Can anybody tell me when you cut the hood of a King Hauler cab is the cut and the floorboard flush with each other or does the cab stick out past the floorboard?
I have been trying to use stock bolt hols and not do anymore drilling than necessary, (trying to keep things clean and simple) but looks like stock hole are probably not going to work. ![]() ![]()
#60
I know when a friend cut my knight daycab the cab / hood the floor pan was a bout 5-10ish mils inside the cab and the normal bottom mount screw holes were removed fron the front of the wind sheild,
And I just made some rectangle ish peices rounds on the front so the hood doesn move side ways when closed.... Hope these pics can help even though its a knight hauler https://fbcdn-sphotos-c-a.akamaihd.n...b2b940a23028ba https://scontent-sjc2-1.xx.fbcdn.net...52&oe=5821D43A https://scontent-sjc2-1.xx.fbcdn.net...ff&oe=58575151 Cheers Tracy
