			#41
			#42
			#43
			That's looking pretty dang good! Tracks look great!
			#44
			Thanks for the complement! I have really enjoyed this build!
			#45
			Very nice build.
	Have been watching it with interest, I have a friend at work that used to work at Bucyrus Erie and actually machined parts for the 40H. He did the big turret gears.  |
			#46
			Hi
			This is a great build thread. Thanks for sharing. I will look forward to watching this progress.
	Regards Mark Over the Pond in the UK Member of Ribble Valley Radio Controlled Truck Club my weather station To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.  |
			#47
			#48
			Nice, I always like these sort of progress photos showing machined parts.
	Jim  |
			#49
			Looks sharp! I've never been able to decide when drilling smaller holes in a part like that if it should be done before or after milling. If before, it's a deep hole and more opportunity for the bit to wander. If after, the ears might bend if too much pressure is applied also causing the bit to wander. Anyone got an opinion or am I worrying about nothing?
			#50
			This will be a nice machine. Real heavy duty parts
	Emil G | MFZ Blocher Fendt 926 | RC4WD Volvo EC480 excavator | Carson LR 634 | Kenworth 6x6 hauler | Kenworth 6x6 dtrk My channel: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Construction site on Facebook: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Pictures on Instagram: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.  |
			#51
			Nice... Looks like fun, wished I had your machining experience....
	David  |
			#52
	RIP FreddyGearDrive 2-12-59/12-19-11 To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.  |
			#54
			Are there any updates on this build?
			#55
			Yes, I have been working on the boom section and it is almost finished.
	I would like to post some pics, but what is everybody doing for a host source?  |
			#56
			Looking forward to see your machine. If you chose Flickr you don't have to deal with ads and crap.
			#57
			I use flicker.com as it's still free.  There are other options, but this is the one that I use.
			#59
			Looking great! Is the stick a solid piece? I'm guessing the boom is solid, too, just two pieces welded together at the bend?
			#60
			Yes, Stick is solid and Boom is solid but welded at the bend. I wanted some weight in the boom to add some "backpressure" on the hydraulics to make the movements more realistic. I might end up having to remove some weight by "pocketing" the underside.
| Currently Active Users Viewing This Thread: 2 (0 members and 2 guests) | |
