Old 11-12-2016, 11:03 AM
Diesel Demond's Avatar
Diesel Demond Diesel Demond is offline
Diesel Demond is on a distinguished road
Default Help
so i have the rc4wd sound unit with airtronics rds 8000 receiver and transmitter.. everything works great for awile and then theres no reverse.. the lights and back up alarm comes on but does not move.. the reverse works perfect when truck is first turned on. i am useing a venom lipo 4000mah 20c 7.4 volt..
Grabbin gears and Rollin wheels ! LETS BLOW SMOKE!!
Member of the Central Plains Mini Truckers,and a Minnesota road hammer.
Flat bedders do it with chains and straps,but now im yanking 53's
Old 11-12-2016, 12:47 PM
Default Re: Help
I'd start by making sure all your trims are at neutral and also check your endpoints to see if they are at 100%. If you have to make any adjustments you'll need to reset the sound system as well.
Bo Wallen's Avatar
Exclamation Re: Help
You might need a BEC to run all consumers !?
Old 11-15-2016, 07:56 AM
Default Re: Help
can anyone tell me which setting the reverse endpoints are for the rds 8000. or were to find them in the remote. i found the 1,2,3 gear..
Old 11-19-2016, 10:17 PM
Default Re: Help
how do i reset the sound system
