| Electronics tech Anything to do with the electronics in a model. Lights, Radio, ESC, Servo, Basic electrical. |
#81
Thank you Espeefan! I couldn't have done it without your diagrams!
#82
Soory, i'm a beginner, in wire links, but on ebay, there are, the leds to 12v.But, if you connect, this leds, directly to the battery, they obviously works.I have wired, this leds, on a lego 42030 ,(7,2 volts) and these ,works correctly.Regards.
#83
I'd like to add a couple of my favorite hacks into this.
If you've got a servo with stripped gears and a soldering iron, you have a remote control light switch! Rip it open, pull the board out, cut motor connections. Leave the radio pigtail alone, the pot can be replaced with a y bridge of 2.2k ohm resistors if you feel like it. Solder your resistor to a motor pad, one leg of the LED to the resistor, the other to the opposite motor pad. Done. Hook up your new creation to a channel in your rx that gives both throws to a servo, lights should come on in one of the not center positions. tweak the pot to have lights off in center if you didn't make it a y-bridge. Cool, it works. Move it to a single throw channel, see if it still works, if not flip the led circuit at the motor pads. Maybe i want to have one set of lights on, turn them off and another set turn on. Wire it opposite at the motor pads as the first circuit. If you are working at normal RC recciever voltage(7.2v stick pack going into an ESC with a BEC for 4-6v output), a 150 ohm or greater LED will safely get your LED working. You won't get peak output, but it gets your unknown lights scavanged off something going without freeing the smoke. Also no math. If you are running red and white leds together like head & tail lights. Make a red circuit and a white circuit. the red need a bit higher resistance or the whites won't work. So my 150 ohm goes on the whites, red gets something 200-400 ohm to start with. I like micro servos since they break easy, are cheap, and someone you know has some broken ones. If you're going crazy with lights, use a bigger servo board since they work with more power. If you're going absolutely insane with lights, maybe that battle switch or a cheap esc is the way to go. Last edited by frizzen; 10-04-2016 at 01:50 AM. |
#84
Thanks for posting that information frizzen! I have some extra micro servos laying around so I hooked one up to the clearance lights and I'm going to do the same for the lights in the cabin.
#85
Can somebody PLEASE tell me if this is a correct diagram for wiring up two LEDs to a circuit?
(+resistor-...+LED-...+LED-) if not what do I need to change to make it work correctly?
Dean Cory Knox, IN |
#86
Yes hooking up series can work. IF you know about what forward voltage the leds need, add them, then find out what resistor you need to make input voltage down to what they need.
I prefer parallel hookups unless you're going absolutely crazy with lights like Smiley, or the Christmas commercial Coca-Cola trucks. It's a few more solder connections, but i think it simplifies things + .. Resistor ... + led 1 ... + led 2 ... and so on - ....................... - led 1 .... - led 2 ... and so on Actual pic of the layout, scroll down to the car bumper picture. http://www.rctruckandconstruction.co...ad.php?t=12930
What do ya mean "Cars are neither Trucks or Construction"? It's still scale, and i play fairly well with others, most of the time... Last edited by frizzen; 12-06-2017 at 09:32 PM. |
#87
I need a source for brown red brown and red violet brown resistors.
I am new to the learning curve here.
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
