Old 04-16-2011, 12:47 PM
rockNmayhem's Avatar
Default Re: CAT 14M Motor Grader
Wow that cab is looking amazing and I like the engine side cover. The added handle looks great as well. So are you gonna have a working door on it so you can access the inside like you did on the cab?
~Tyler~
RockSolidCustoms
Old 04-16-2011, 09:34 PM
SonoranWraith's Avatar
It's a dry 115 degrees.
I just about pee myself when I see an update to this thread.
Old 04-16-2011, 11:55 PM
Jared Jared is offline
My chin is getting bruised up bad from my jaw dropping every time I see an update.
Old 04-17-2011, 12:25 AM
TheMachinist's Avatar
Absolutely beautiful!
I love the smell of fresh cut aluminium in the morning
I can't wait to see the blade frame and turntable hanging off it.
Old 04-17-2011, 11:35 AM
Today I made the right hand side of the engine cover. Again this is a good example of these modern machines, round shapes equals good rear visibility, but quite difficult to make
Old 04-17-2011, 06:20 PM
Very nice milling. What program are you using? I maybe in the market for a new one. I've been using Bobcad 19 for some time with my old Bridgeport with a ProtoTrak MX3 control. I got V22 but never used it because v19 was easier for me. Last week my old computer took a dive and now with windows 7 I'm having problems. The biggest one is it prints completely black pages. I had that problem with v2007 and v22 but never could fix it. Sorry to change the subject.
Old 04-17-2011, 07:48 PM
Azorean Azorean is offline
Azorean is on a distinguished road
Thumbs up Re: CAT 14M Motor Grader
WOW... that´s amazing.
keep the great job.
Old 04-20-2011, 12:36 PM
I´m using program called Pcdreh (Pcturn). It´s a CAD/CAM software, and very simple to use.
Here is couple of pictures of the engine cover, I manage to make the front and rear pieces
Old 04-20-2011, 02:16 PM
td9clyde td9clyde is offline
Dozer Builder
very nice work how long is it?
Old 04-20-2011, 02:32 PM
It´s just under 27 inch long.
Old 04-20-2011, 04:06 PM
Dozer Builder
That grader is a masterpeice i really like it seeing alot of the builds in aluminum makes me want to try aluminum but the stuff is so hard for me to work i think i will stick with my metal .......how wide is the molboard? and the width ,and weight i have been watching this build it just amaizes me keep up the awsome work
Old 04-22-2011, 11:45 AM
Today I made one of the side ventilation hatches, and the lower back piece.
Old 04-22-2011, 01:46 PM
tc1cat's Avatar
tc1cat tc1cat is offline
Super Moderator
Question Re: CAT 14M Motor Grader
What a build!! Just keeps getting better with each update. Truely amazing what you can do with CNC equipment and a good Cad/Cam system. I do have a question for you: With all of the detail you are putting in this vehicle, why did you only put less than 1/2 of the number of bolts in the drive line compared to the pics you show of the real thing? I realize that it won't be seen very easily but looks like it wouldn't have been much harder to make completely prototypical???????
LYNN
Old 04-22-2011, 02:17 PM
rc_farmer's Avatar
Master Builder
The machine is only as smart as the programmer......Top-notch work
Giving up is not an option!!!
Rob
Old 04-22-2011, 03:02 PM
You sure are good at programming your parts. Very ingenious way of simulating your door panels. I've seen this done on lazer cut sheets and the designer burned shallow lines for the press brake operator to know where to make his bends.
Old 04-25-2011, 09:45 AM
Today I made the front bracket for the articulation cylinders
Old 04-25-2011, 02:33 PM
Ari it is looking great and seems to be coming along nicely. I like the way you made the vent panels but one question I have is how are you going to keep them mounted to the side pannels? I don't see any mounting holes in them.
~Tyler~
RockSolidCustoms
Old 04-25-2011, 02:46 PM
I stand in awe at your talent. What more can I say? This model is right up there with the best of the best I have seen on the forum. Incredible. If only I had a fraction of your talent to build something even 1/4 as good! Yikes!
Old 05-01-2011, 05:55 AM
This weekend I started to make the blade circle
Old 05-01-2011, 07:41 AM
Panther F's Avatar
So awesome I tell you. Manufacturers should take note ... the cab work is so beautiful!
Thanks for the pictures!!
- Jeff
