Old 08-22-2010, 09:17 PM
SmallHaul's Avatar
Cool Cool tranny mod for front wheel drive (Vid added)
I made this up today, it is no done yet though. I ordered flanged bearings for it and I have to make nice stand offs for it but, it actually works as is.
Scott
"No load is too Small"
Old 08-22-2010, 09:30 PM
SmallHaul's Avatar
Default Re: Cool tranny mod for front wheel drive
Short vid:
http://www.youtube.com/watch?v=6KrCl8c0uhI
Scott
Old 08-24-2010, 11:27 AM
SmallHaul's Avatar
Default Re: Cool tranny mod for front wheel drive (Vid added)
I made a cover for it. I will use some clear silicone to seal it up when I get the bearings installed:
Scott
Old 08-25-2010, 12:03 AM
Bob From Downunder Bob From Downunder is offline
Bob From Downunder is on a distinguished road
Hi Scott this is fantastic, well thought out and has a lot of protential for 6x6 users. Can you please tell me where you bought the gears from. This is what I have been searching for. All I need to do now is find a way to disconnect the front drive.
Bob
Old 08-25-2010, 02:14 AM
Thanks for your info Scott, I just ordered this morning from RC4WD a disconect unit and some gears so I will play around with it when they arrive. All part of the enjoyment I suppose.
Bob
Old 08-25-2010, 10:32 AM
SmallHaul's Avatar
Bob
You can find all of the gears on ebay. I used 32 pitch.
I used two 18 tooth pinion gears (5mm bore)
http://cgi.ebay.com/Traxxas-Tra5644-...efaultDomain_0
and one 22 tooth pinion gear
http://cgi.ebay.com/Traxxas-E-Maxx-2...ts_Accessories
The size of the center gear will not change the ratio as long as the 2 outside gears are the same. So, you could run a 28t 32p gear for the idler gear and that would lower the final output shaft a little.
28t 32pitch 5mm bore gear:
http://cgi.ebay.com/CASTLE-CREATIONS...ts_Accessories
Scott
Old 08-25-2010, 11:44 AM
Scott , Your right till you get to "would lower the final output shaft a little." It dose not matter what size Idler gear as long as the input and output are the same you would not change the ratio . Now If you are referring to changing the out put to a 28 tooth then yes you would lower the ratio. All Idler gears do is keep the output same rotation as the input . But very good Idea as the same for willy ( custom rc models ).
IHSteve
Old 08-25-2010, 12:03 PM
SmallHaul's Avatar
Steve, When I said "would lower the final output shaft a little." I meant lower the height of the output shaft not the ratio.
Scott
Old 08-25-2010, 10:50 PM
thanks a million Scott, I'll have a go at building one.
Bob
Old 08-25-2010, 10:56 PM
Sorry my bad no offense
IHSteve
Old 08-26-2010, 12:00 AM
I think the extra axel driving will make climbing steep grades much more easier.
Old 08-26-2010, 12:03 AM
SmallHaul's Avatar
You are welcome Bob but, I wouldn't recommend doing this conversion unless you have the time and tools because an axial trans or an f-350 trans would be a lot easier.
It probably took me 6 or 7 hours to make this but, every time a drive it I will be rewarded that I made it myself. It should sound really cool when it is done because there 8 gears driving against each other from the motor shaft to the final output shaft and there are 2 sets of those gears in metal cases, the hpi GRU and the GRU I made.
No offense taken Steve!
Scott
Old 08-26-2010, 02:59 AM
no worries mate time I have and the willingness
thanks for all your help, very appreciated.
bob
Old 08-28-2010, 04:18 PM
Blueshirt Blueshirt is offline
Blueshirt is on a distinguished road
I'm always jealous when I see someone who has the talent to make somthing like this instead of buying it. Nice Job!
