Old 11-19-2011, 08:26 PM
Brian in PA's Avatar
I'd rather be truckin'
Default Re: Nick's 379 build
Nick, where are your pics?
Brian
Old 11-19-2011, 10:14 PM
aussierolla's Avatar
aussierolla aussierolla is offline
aussierolla is on a distinguished road
could make the cab mounts out of styrene then glue them on to cab the screw up from under the floor panel into the new cab mounts just a thought
Old 11-21-2011, 05:49 PM
Snowman's Avatar
Snowman Snowman is offline
Thanks guys, I know how I want to mount the cab and sleeper, it's just a matter of figuring out how precisely to do it. But I think I got is sussed.
Brian
Brian, can't you see my pics? Or do you mean you want to see more?
Nick
My Peterbilt build thread:
Old 11-21-2011, 08:42 PM
They weren't there the other day, but they are here now? You can post more!
Brian
Old 11-23-2011, 06:30 PM
6wheelking's Avatar
6wheelking 6wheelking is offline
6wheelking is on a distinguished road
hope you got a nice set of bags for the front cause thats real low nice work
It maybe small, but its still big
Old 11-28-2011, 07:36 PM
Snowman's Avatar
Brian
Ok well here's some more pictures of the business end. Not much to report, but I made some adjustments to the fenders to rout the wires coming out the headlights. Also figured out how I'm gonna mount the bumper, using some doll's house hinges bolted directly to the underneath of the grille, as you have done Brian on your trucks to hinge the hood. That will give me the pivot to flip the bumper up as I'm gonna have clearance issues otherwise! Not mounted the bumper yet, that will have to wait now till the grille is ready.
You can also see how I've secured the front of the body, I made a tab from a scrap piece of frame rail that hooks the horizontal bar behind the grille. Then I'll just make some tabs at the back of the cab on the inside and screw them down
Thanks, I would have bagged it like a 1:1 but to my knowledge there is only one place to get working bags and they ain't cheap!
Nick
Old 12-04-2011, 08:36 PM
straightpipejakebrake straightpipejakebrake is offline
straightpipejakebrake is on a distinguished road
Can't wait for more pics...
Old 12-04-2011, 09:29 PM
Its gotta pretty mean stance!
Brian
Old 12-06-2011, 06:00 PM
Snowman's Avatar
Thanks Brian! What do you think would look better, 3 bars or 7 bars in the grill? I'm working on mounting the bumper as we speak.
Then I'll mount the pipes, something I've been putting off as I don't want to mess it up! And then I might finally cut out the windscreen too...
Nick
Old 12-07-2011, 07:16 PM
Snowman's Avatar
Well, here's a little progress. I finally did the flippin' bumper. Or rather, the bumper flip! Just need to fit a servo and linkage to operate it.
I'll be painting the hinges black to make them more discreet.
Next is to mount the pipes and then cut out the windscreen/make a visor.
Did a test run indoors and the bumper scrapes on the carpet!
Nick
Old 12-07-2011, 08:17 PM
sneaky-pete's Avatar
Master A-Modeler
That is bad @ss Nick!
Your ride is coming along nicely!
Troy
Old 12-09-2011, 03:57 PM
Snowman's Avatar
Thanks Troy! My inspiration comes from everyone else's cool builds.
I've got a problem with the headlights, only the outer ones come on, there must be a break in the wiring somewhere for the inner leds I hope the break isn't close to the led inside the light unit, took me a long time to stuff them in there!
Nick
Old 12-09-2011, 07:57 PM
CustomClod CustomClod is offline
CustomClod is on a distinguished road
This is looking sweet! Nice work!
Scott
I run a single stack Mack with a dump body on the back!
Old 12-12-2011, 08:53 PM
Snowman's Avatar
Scott
Thanks Scott!
Well, a little update. Finally fitted the stacks. I need to fine tune their positioning so they are completely symmetrical. Here's a few pics. Next to do is cut out the windscreen and make a drop visor. Then I'm going to work on dropping the rear a little more.
Nick
Old 12-12-2011, 09:40 PM
Master A-Modeler
Wow Nick,
That truck is looking better with each update!
Keep the picks coming....your on a roll.
Troy
Old 12-13-2011, 03:15 AM
Wow, it's looking really good, Nick! I'm guessing if both your inner LEDs do not turn on, then you must have something else going on. Hard to believe you'd break the leads or wires on both inner LEDs, don't you think? Maybe an MFU problem? Or whatever lighting kit you are using.
Keep it up! This will be right up there with Brain's Pete when done.
Old 12-13-2011, 08:42 AM
Snowman's Avatar
Originally Posted by sneaky-pete View Post
Wow Nick,
Thanks Troy! Appreciate it. I hope to have more to show soon.
Thanks Nathan, if it's half as good as Brian's I'll be extremely happy.
The LEDs are wired in pairs in series, so it only takes one to be faulty or a break in one wire for neither to work. It's hardly surprising, they are crammed into those headlight housings. I've eliminated the mfu as other lights work in all the outputs. So I'm gonna have to try and isolate the fault with the led pair. It might mean removing the heatshrink where I've cut and re-soldered the LEDs
Thanks for all the comments guys!
Nick
Old 12-13-2011, 02:21 PM
SWAGGER's Avatar
SWAGGER SWAGGER is offline
I would agree with your suspicions, sounds like they are crammed in quite tight to those little lighting housings, chances are that an led leg snapped!
Had a feeling you where in the UK before I even looked at your location. The little red pug in the background was a dead giveaway. I take it that it's the 1.9 GTI. Those things where famous for rolling over LOL!
Old 12-13-2011, 06:32 PM
Snowman's Avatar
/Nostalgic car related off-topic
They were certainly famous for putting people through hedges backwards if they drove them like fools! That car demanded respect and rewarded you for good driving but would just as quickly turn round and bite you on the bum if you pushed it!
I owned 3, loved them. Most fun car I have ever driven. Could feel everything through the chassis and could just flick it round corners. The engine in my last one pulled like a freight train. But then it used to fart and snort when sitting in traffic for too long. And the electrics were a bit of a mystery. Still, the shell had not a sign of rust, not bad for an 18 yr old car! I used to love surprising drivers of cars whose alloy wheels probably cost more than my whole car!
/back on topic
Nick
Old 12-13-2011, 08:01 PM
gun's Avatar
gun gun is offline
HillBilly Home Boyeee. WAZZZUP!
gun is on a distinguished road
the truck is really looking nice ! love the stance and long wheel base. the hood and pete fenders look great and i really like the shinny tires ads to the show truck in the making look. now all it needs is to be painted bright yellow and shiped to me and every one will be happy ! well id be happy ! lol keep up the good work
SHANE... Member of the Central Plains Mini Truckers..
