Old 09-01-2010, 09:48 PM
SmallHaul's Avatar
Default Helical gear set for tamiya semi trans?
http://www.stellamodels.net/catalog/...U009Banner.jpg
Stella models site
Scott
"No load is too Small"
Old 09-01-2010, 09:50 PM
SmallHaul's Avatar
Default Re: Helical gear set for tamiya semo trans?
http://www.stellamodels.net/catalog/...oducts_id=5071
$50 not bad.
Scott
Old 09-01-2010, 09:58 PM
Default Re: Helical gear set for tamiya semi trans?
Please post items like this in the tech page and leve highway trucks and trailers for build threads.
Thanks
Travis
Old 09-01-2010, 10:12 PM
SmallHaul's Avatar
Oops..I'll remember that for the future.
Scott
Old 09-01-2010, 10:16 PM
No problem Scott we are all still getting use to things so keep the helpfull ideas comming.
Travis
Old 09-01-2010, 10:25 PM
Claus's Avatar
Claus Claus is offline
I seen those gears on ebay, my first thought was has anybody ever stripped their Tamiya gears? Those stock transmissions seam pretty bulletproof to me.
Old 09-01-2010, 10:26 PM
SmallHaul's Avatar
So, has anybody actually had a plastic transmission gear fail? Joe(littleGIANT)?
Scott
Old 09-01-2010, 10:39 PM
Scott , if I remember right from a conversation with joe when I started He never had an issue . After building my first 1 , It seems you have to wear the bushings out before the gears start to fail and make sure you keep it lubricated well . also the brass will bind faster than the plastic if not greased well .
Old 09-01-2010, 10:52 PM
Tamiya Cowboy's Avatar
Joe has never wrecked a tranny so they are very tuff. Them gears first came out last year threw GTD stella must of bought them out of it. I have a set just need to build a truck to use them in. The tranny will be a lot heavier and will sound a lot different other than that cant see the use..
Paul W. "Tamiya Cowboy"
Old 09-02-2010, 12:14 AM
Claus's Avatar
If such a truck exist it's your oil field KW.
Old 09-02-2010, 12:41 AM
That is what I wanted them of when i was building it and it was bout that time they up and vanished so that is what i am thinking is pull that gear box a part and put them in there. I just want to hear how they sound.
Old 09-02-2010, 02:58 AM
In the 1:1 world, helical cut gears are done for the purpose of quieting down the gear noise. Straight cut gears will always make more noise, and be stronger. I wonder if this will apply to the Tamiya 3 speeds. Will they be quieter? Course the metal helical cut gears should be stronger then the straight cut plastic, but even so, if they hold up for Joe, the average guy will never wear them out!
Old 09-02-2010, 09:04 AM
tc1cat's Avatar
tc1cat tc1cat is offline
Super Moderator
I have to agree with Espeefan on this. Helical metal gears should be quieter than straight cut metal gears. I don't think they will be quieter than the Tamiya plastics gears though.
Old 09-02-2010, 09:49 AM
Thorsteenster Thorsteenster is offline
Thorsteenster is on a distinguished road
I got into a minor dispute with a guy om tamiya3speeds forum, did a pole on Scale4x4, and I have never heard of a gear failing/stripping in a semi or High Lift trans. So strength wise I see no need, and yeah, as tc1cat says, being helical metal gears, they would be quieter than straight cut metal gears, but I doubt quieter than the plastic.
Now, for unseen coolness and bragability about helical metal gears, **** yeah!!
I'd run my trans with no case or make a lexan one.
Call me Thor, it's short for Thorsteenster.
In VA? Check out
