Old 09-03-2010, 11:05 PM
Thorsteenster Thorsteenster is offline
Thorsteenster is on a distinguished road
Default Re: Powered all-thread and nut lift
Please guys, if you're going to start introducing other than standard screw drives, explain a little what they are!
Call me Thor, it's short for Thorsteenster.
In VA? Check out
Old 09-03-2010, 11:22 PM
Thorsteenster a liniear acuator is a smal screwdrive built to look like a cylinder. Here is a pic.
Travis
Old 09-03-2010, 11:43 PM
Travis, what's the smallest linear actuator you've found or seen? I've only see the big ones.
Ahh, nice, I've looked into those before for steering on a crawler. That's the Firgelli, do they work well and worth the money?
I was actually laying out some plans for making something similar using a tiny GRU/motor combo from Pololu.
In VA? Check out
Old 09-03-2010, 11:56 PM
Espeefan the smallest one I have seen has a 10mm Stroke. Izzy has some on his dozer and rc guyfarms has some on his belly dump pups and they seam to work great.
Travis
Old 09-04-2010, 12:38 AM
Wow. That's a lot smaller then I would have imagined they made. Thanks. Good info.
Old 09-04-2010, 01:48 AM
SonoranWraith's Avatar
It's a dry 115 degrees.
Here is a pic for reference of what I am talking about (not my build):
That is Jurgen Ritter's Fendt and all his machines are truly works of art. One of the brass cylinders is a spindle, the other has the limit switching!
