#41
awesome looking Loader Steve , wonderful job so far can't wait to see more. on a side note I would really like to have thouse rims from that Knight hauler they would look great on my Autocar lol
#42
![]() HOLY COW! Now that is a loader Steve nice work!
#43
those are my 1st and will be hard to part with since they hand carved in hard brass I think thats why the bearings are just about shot in my dremel thanks Paul , need this done soon . I'm tired of shoveling to load the mack ![]() ![]() now I got to get me some brass for the body
#44
some more parts came in from the shop
12#counter weight Z link piviot . since I was snaping picks I through a 36"ruler in the pic for size ( 31.5" long from back of counter weight to tooth tip on spade bucket . #30" with std. GP bkt.) I hope these pics are better .![]() ![]() ![]() ![]() ![]() thats it for now till I get this guy to make me more parts ![]() ![]()
#45
This is going to be great when it is done it is so massive just a very cool build Steve nice work.
#46
Great work Steve!
Brian RIP FreddyGearDrive 2-12-59/12-19-11 |
#47
Wow ! Awesome work you have done on this loader so far.Bucket detail is awesome,very cool
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#48
That is just massive and looks great so far!
#49
yes it's getting bigger and packing on the pounds up next will be new axles I was going to go with what I have for now but after puting the counter weight on , I think I better make them now I got some good picks of how the rear axle pivoit is , so I'll be making that more scale also . stay tuned
#50
snuck in the drop box and motor mount today
Using a manual speed control (MSC) I did a speed test of course it's always dark till I get to take a vid ![]() FWIW , plenty of room yet to put pump and valves ,etc. also , motor is from a 24v dewalt 2 spd. hammer/drill .![]() http://youtu.be/1FNU7pUVjPA thanks for looking
#51
Looks smooth Steve. Where was hammer mode. Lol. Betcha can't run it through the wall.
What the trac-hoe in the background, kids toy?Ben
#52
Gotta like that "Armstrong Steering" great progress!
Cheer's, Neil. |
#53
![]() it has enough torq and the right weight with the teeth , that drywall is a gonner . yea kids bruder I need to get all I have started at least working before I dive into the excavator I have planned
#54
![]() ![]() Ben
#55
Very impressive!
#56
that loader is going to be a horse lol nice work one of these days i will get the two others i have working and then i will start on a couple new ones lol
#57
Get it in gear Henry!!
#58
#59
Wow, that's a nice looking loader. You sure have some talent at building. Did you ever get your hydaulic pump going or are you building another one? Will you buy or make cylinders? I think you said on your Mack, another great project, that your cylinders did not work out. Did you ever think about just buying a longer air cylinder, cut it to length and then make new ends. That way you get a finished bore and rod assembly that you know will work. You would only need seals and bushing for the rod end.
Richard |
#60
Rich , I had trouble on the tele cylinders for the mack only do to not enough time on them
(rushing ) what I have now acctually works better anyways . I'll be making these ( walk in the park ) I even found actual wiper seals that'll work for the size . I have a couple pumps from index to play around with . 2 have motors on them . the problem with these is the magnetic coupling which is no problem to change (again , lathe time the mill always is ready for more work for some reason ) ) I still have a sickle set of gears like what the jung pump uses , that I need to make a housing for .
| Currently Active Users Viewing This Thread: 13 (0 members and 13 guests) | |
