| General Discussion A place to post off topic discussions. |
I was ordering a couple bits from McMaster and got to looking through their hardware and ended up ordering 50 stainless 3mm X 20mm hex head screws, washers, and locknuts. I got the 20mm ones because they are fully threaded so I can cut to length.
I don't know how big the hex is, but the "mini bolts" ought to look pretty cool. Anybody else used these before? Typically I order screws and nuts from http://www.microfasteners.com but they only have the hex head screws in SAE sizes.
Call me Thor, it's short for Thorsteenster. In VA? Check out To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Thorsteenster; 09-08-2010 at 12:36 PM. |
Hey Thor,
I have used microfasteners.com before. I have ordered from them twice. The first time I basically ordered one package of every micro brass hex size with the accompanying nuts. The second time I ordered, refilled some of my depleted bolts and bought the small nut drivers specifically made for them since they are tiny little buggers. I have been using the bolts for my Tamiya tractor truck build and so far, it is looking killer. What did you have in mind for these? Dan |
Well I found MicroFasteners a few years ago, and ever since have really wanted to use the hex heads on something but not being metric I didn't want to have to worry about threading issues.
I'll be using them for building my Volvo'ish truck. My screw box is pretty scarce so I needed to replenish anyway to hold it together once I get going. I'll use the M3 for main assembly, then get a better idea of needs and order some smaller sizes from MicroFasteners. I'd like to have all the fasteners "nuts and bolts".
Call me Thor, it's short for Thorsteenster. In VA? Check out To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
You might want to try www.fastener-express.com for metric and SAE nuts and bolts. They have a very large range of sizes and types of materials used. Prices are not too bad either.
Thor. I've used a company in Florida for small hex bolts for my steam engine. They are American Model Enginer Supply. Quite a slection of sizes, both steel and brass. Rob
http://www.americanmodeleng.com/id41.html |
I use brass M3 hex heads, though I bought overseas. Really low head height of only 1.7mm. Some of the 3mm stuff I have seen still has a bulky head height. I also have 2mm acorn nuts for my wheels because I don't like the socket cap screws. I still use stock screws for stuff that doesn't show.
Pic is a little dark:
Thor, I use stainless steel socket head cap screws exclusively on all of my builds. I hate the look of phillips screw heads, and worse, the way they tend to round out so easily. I've got a huge stock pile of 2mm, 3mm, some 2.5mm, and some 4mm socket head cap screws. I will never build a model with the provided hardware. I never have.
To me, socket head cap screws look so much nicer, even if they still aren't scale. I get everything from McMaster.
Nathan |
Thanks for the replies guys, glad I ordered the hardware. I'm sure it'll look great!
Well I got them today, and I must say initial impression is they look pretty darn good. The head size is the same as a regular Tamiya 3mm nut.
Oh yeah, they're Italian too!
| Currently Active Users Viewing This Thread: 2 (0 members and 2 guests) | |
