| Big Boys of the road 4x4/6x6/8x8/10x10 Trucks This forum is for those multiple axle trucks and other vehicles on and off road. |
			#41
			i know you can get 80lb fishing line at academy i used for winches on my scale trucks and i never broke it and very flexible
			#42
			That winch looks great!
	Kerst  |
			#43
			This is a really nice build.  Plenty of mechanicals and metal work to keep me very interested!  You asked about a smaller roller chain.  Diamond Chain makes #47SS, a .1475" pitch roller chain.  Should be able to source it through a local bearing house - anyone that carries Diamond chain.  See it at http://www.diamondchain.com.  Also, http://www.pic-design.com and http://www.nordex.com have this size.
	Big iron is awesome!  |
			#44
 Thanks for chain tip sparkycuda i need to look into this before i anchor winch could give me a little more room Thanks Kerst Update: i wanted a sliding fifth wheel plate so i used some gear rack on its side with sliding block wedges to lock it all up. i keep thinking there has to be an easier way???? in the pic one block is slid up in lock the other is back. when done these will be covered.
	Waiting for Parts!  |
			#45
			updates
			![]() ![]() Lift test ![]() lift test was a success so far my problem area is the front axle. those cv joint drive pins broke again   replaced them again. i think it has to do with the angle of turn there are no stops on the axle so if you turn as far as it will let you it shears the pin hiiiiim, also the servo for turning has been increased in torgue twice and works good at first but latter both servos seem to lose power and cant turn wheels full turn unless moving? current servo is a JR DS8711 347 oz/in torgue. back to drawing board on those items. the turning radius finally settled at 3 feet not to bad down from 5 feet before moving rear boggie. i foamed filled the two front tires with a product from smooth on and no more flats. .jack weighs 34 pounds ![]() on the water tank (battery box) in the video are two hatches the one on the driver side which is open is the were the kill switch for the battery is. charging jack is opposite that on the bottom of the tank next to that will be the fuse. i need to hook up the lights and lighting kit which is mounted in radiator housing. and install some tanks. and a lot of little add on and adjustments. Enjoy. Thanks Don
			Waiting for Parts! Last edited by mack kid; 07-17-2012 at 02:13 PM.  |
			#46
			Awsome build!
	I love so many things on this. Gullwing bonnet, very nice (I was thinking of doing one on my army truck build, but decided on standard type). Battery compartment water tank looks great, that winch is mean as and the whole thing just has a great stance to it.  |
			#47
			Here is update its been a awhile because of front drive axle. this axle cant take the weight i had this axle out 5 times!!! well it no longer is a drive axle. i gutted it and changed the king pin set up, lowered steering servo and so far much better. i wanted a front drive axle but not to be. in the first dirt test it did good so iam not going to worry about it.
			![]() here is finale drive covers ![]() ![]() ![]() so far its a runner i have a whole buch of little stuff to work on but i can now move on to other rigs.(i hope) the front axle was a nightmare. i need to get differant BEC to power the lights the one i was using blew yesterday?   its like ownng a boat  hope to start on one of two trailers built just for this rig.
			#48
			Awesome job on the build.That thing is a total beast.To bad about blowing out the front diff.
			#49
			That's one **** of a lot of truck, what do you plan to do with it?  Nice build.
			#50
 Thanks Claus. i plan on building 3 pcs of construction equip in 1:10 scale. this will be the heavy hauler. the low boy trailer is next along with a dump trailer. a little big i know but the equip will be too. here some pics. thanks Don
			#51
			Don i missed the last update, man this thing is looking killer!! and lifted a 34lb jack!! Nice!!!! Love the look of it!   That sucks about the front axle.. keep up the great work!!
	Hi my name is Aaron.... And i'm a truckaholic!  |
			#52
			Man that is one awesome looking truck really nice job.
	Congrats  |
			#53
			I love this truck. She's a bigone! Very cool man.
			#54
			Nice looking truck! I really like the wheels and tires!
	-Chris To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.  |
			#55
			Thanks Bigrigger,Cyanide,Crazy4yachts,dabears
			my new handles came in and i started the decals enjoy ![]()
			#56
			Ok 2 things.... 1 Love those handles where they from??? And your gonna need to make me a few sets of those plates!! As in Ill FF myself i need some of those! SWEEET!!!
			Truck is looking very cool and keeps getting better and better!!!
			#57
 Try using this
	-J.D.  |
			#58
			#59
			This thing is awesome I have always loved these bit logging rigs you are doing a great job and i cant wait to see more..
	Paul W. "Tamiya Cowboy" HI.. My name is Paul.. And.. I.. Have a Cabover Addiction. RIP FreddyGearDrive 2-12-59/12-19-11 "LET IT EAT" Like Us on Facebook "Corn Field Mafia" To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.  |
			#60
			Thanks dabears and YoungGunz
			the handles are really nice there from http://www.ozarkminiatures.com/scrip...?idproduct=552 and 10 for the price i could not use http://acme.com/licensemaker/ i could not make the size i needed so i got this kit The number #3 kit it works pretty good works best if you have a picture program to work with like photo shop or coral draw. also you will need testors decal spray or the ink will run i got a can from hobby lobby. http://www.decalgear.com/DG/Category...ode=DM_BUNDLES so far its a lot computer work but i like it done what you see with publisher and decal program and paint program. but i am buying a photo shop program. you can get free programs like that on the internet too.
| Currently Active Users Viewing This Thread: 2 (0 members and 2 guests) | |
