looks great i like this build we need a 140 to grade the haul roads for all the pans now .....so far DP Joe has the smoothest ride lol in a dozer while the rest of use bounce around on these ol pans
Rob, what are you using for a circle gear? Very nice work.
Joe |
Rob that grader is really taking shape I like it a lot. Talking about radio the F16 can be made to 2.4GHz and have an extra stick also it dual layered Scale Art told me. It has 15 channels plus 6 in 2 layers the price is 689.70 Euro or $940 US. I guess it will even brush your teeth if you want it to. The only problem with it I can see is if you have a problem with it it has to go to Germany to be fixed. Ed
Joe, i am going to use a chain, sprocket and geared motor. I made the ring and i plan to have the chain tacked welded to the ring. I have a machinest that will make the retainters for the ring to ride on. Thats the current plan. I would like to use the worm gear method like on the real one, but haven't quit figured out to make that work. It would lok more scale than the idea that in my head at the moment.
![]() I am figuring things out as i go.Thanks for the compliments!
#26
Joe |
#27
why not cut your own ring gear and make a smaller one for on the drive motor for it ?
#28
I am going with this: http://2wheelhobbies.com/product_inf...roducts_id=316 http://2wheelhobbies.com/product_inf...roducts_id=311 I believe this is equievelant to #25 chain
Giving up is not an option!!! Rob Last edited by rc_farmer; 10-03-2010 at 11:40 PM. |
#29
5 spool valve $ 478.00
pump/motor $ 335.00 Airtronics 10 ch $ 429.99 (with nine 3-pos switches) Priceless!
#30
very good looking build! when do you think it'll be running?
#31
Hey Rob when you figure out how to work that 10 channel Airtronics let me know. Ed
#32
Ed, I think the radio might be my one and only Christmas present...
![]() I plan to have it completely working by mid-summer '11 I have come to terms that hydro is only way to go. I have tested the air theory and it just will function like i want it too. Air can't be adjusted.
#33
Rob good luck with your endeavor. Every time I think everything is going along smoothly something always through a monkey wrench in the mix. Ed
#34
is this hotrod somewhere in the 1/9 to 1/10 scale?
#35
I would say it is 1/10 scale in size..
Paul W. "Tamiya Cowboy" HI.. My name is Paul.. And.. I.. Have a Cabover Addiction. RIP FreddyGearDrive 2-12-59/12-19-11 "LET IT EAT" Like Us on Facebook "Corn Field Mafia" To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#36
Update to the grader pics:
![]() ![]() ![]() ![]() ![]() ![]() I have started to put some paint on a few pieces....will post more later.
#37
Rob your looking good your really coming along slow but sure nice job. Ed
#38
Thanks Ed, yeah its really slow, but it's starting to pickup a lil bit. Some of my parts where i need strength, i build the prototype out of wood then have them water jetted in aluminum......just spent 20 bucks on 2 can of Cat yellow, but it worth it. gonna start ordeing hydraulic parts after Christmas.
#39
Rob I left you a pm. Ed
#40
Rob, have you thought about using the "Switch 8"
This is quit interesting, making it out of wood is different, wish I could work with wood like that. VERY NICE. -Mike
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Mike "DREAMWEAVER" Johnson To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. RIP FreddyGearDrive 2-12-59/12-19-11 Rims and Tanks by ihbuilder / Grill and Visor by Brian in PA / Mirrors, Front and Rear Bumper, Back of Cab Lights, and Steering Arms by tc1cat / Fenders by Stylin n Profilin / Frame Rails by The Late Freddy Gear Drive |
| Currently Active Users Viewing This Thread: 4 (0 members and 4 guests) | |
