Old 05-06-2013, 11:59 PM
Claus's Avatar
Claus Claus is offline
Default Re: Snochaser's Construction Co. Builds
Looks as nice on the inside as it does on the out.
Old 05-07-2013, 02:22 AM
max52 max52 is offline
max52 is on a distinguished road
compliment nice job
Old 05-07-2013, 04:20 AM
Wow, that's a one of a kind machine! Such a well thought out platform too. Everything fits perfect, like it's meant to be. No doubt you had it all in your head as you started building it! Very clean work.
Old 05-07-2013, 10:08 AM
SmallHaul's Avatar
Very nice work Ben! It looks and runs great.
The gearing seems spot on.
Nice work on the wheels Steve the look great too.
Scott
"No load is too Small"
Old 05-07-2013, 01:12 PM
pigeonfarmboy's Avatar
Looking killer Ben!
Old 05-07-2013, 01:34 PM
Finster's Avatar
Finster Finster is offline
Finster is on a distinguished road
Really awesome build so far! Looking forward to its completion and seeing some videos. I imagine this is an 'outside only' use machine with those wheels (well at least here on hardwood floors and the SO around). Quick questions:
What thickness of brass did you use for the frame parts?
Did you soft solder or silver solder it?
(I saw someone ask earlier but couldnt find the answer)
Are the wheels made up as rings with spacers? Are they bolted together or
welded or glued?
Thanks
Brian
Finster shavin' and smokin' a cigar?!?!
Old 05-07-2013, 06:20 PM
ihbuilder's Avatar
"Are the wheels made up as rings with spacers? Are they bolted together or
welded or glued?"
generally , 5 pieces bolted together . but a lot more went into it then just that . it would've been too time consuming to weld every foot on each wheel
Old 05-07-2013, 07:29 PM
Snochaser's Avatar
16g brass. Silver solder.
, you will not be forgotten.
R.I.P. FGD
Work Hard, Play Hard!
Never Forget- 343
Old 05-21-2013, 02:42 PM
Nice job! The speed on the video was very scale.
Old 06-26-2013, 02:26 PM
ngward79's Avatar
ngward79 ngward79 is offline
ngward79 is on a distinguished road
Great job ! Any update pics or video ? And anybody have a link to this current video of it that I can't seem to find ?
Old 06-26-2013, 08:54 PM
Snochaser's Avatar
Nothing to update, been extremely busy. Click on the picture in post # 248 for a video.
Ben
R.I.P. FGD
Never Forget- 343
Old 06-27-2013, 04:25 PM
rc_farmer's Avatar
Master Builder
WW Ben......that is truly awsome my friend. I can't wait to see this in person.
Giving up is not an option!!!
Rob
Old 06-28-2013, 12:38 PM
tc1cat's Avatar
tc1cat tc1cat is offline
Super Moderator
For some dumb reason, I have missed this thread . Ben you have out done yourself this time The video looks great as does the entire model. My only very small complaint is: why didn't you use brass for the entire body?? You were so close!! No, all kidding aside, between you and Steve- the wheels- this is one outstanding vehicle. Can't wait to see it completed! Indy, maybe????
LYNN
Old 06-28-2013, 06:17 PM
ihbuilder's Avatar
might be an older 1 there too
Old 06-28-2013, 08:12 PM
ngward79's Avatar
Hey , no teasing ! Let's see it ! Lol...
Old 07-23-2013, 06:41 PM
Tick tock! hahahaha (me too)
Old 08-11-2013, 09:49 PM
Snochaser's Avatar
I'm trying to get the steering cylinders to cycle faster, do I increase pressure in the pump? I'm not sure what pressure I'm running currently. Ideas???...
R.I.P. FGD
Never Forget- 343
Old 08-11-2013, 10:10 PM
Larger lines going to the cylinders, smaller diameter steering cylinders, or turning up the pressure on the pump would be the only ways I know to speed the steering up. That or run the pump faster. More voltage, though I don't know how much more you could run before you compromise the reliability or longevity of the pump. You could consider upgrading the pump motor to the brushless motor that Leimbach offers. I know that motor spins faster then the brushed motor.
Old 08-11-2013, 11:02 PM
doodlebug's Avatar
More pump volume, pressure has to do with how much load is placed against the pump.
Cheer's, Neil.
Old 08-11-2013, 11:10 PM
Snochaser's Avatar
Ok. I'm already using the largest line I have, 2.5 I believe. I've thought of the bigger lines, I guess higher moor speed would help in crease the volume I need.
Thanks guys, I will have to look into the brushless option Nate. Do you have a link?
Ben
R.I.P. FGD
Never Forget- 343
