Old 12-15-2013, 11:13 AM
Fired up Fired up is offline
Smile Re: New member. Building D8
Thanks far cry from some of the detailed builds on this forum hope it works as good as some that I have seen here.
Old 12-15-2013, 02:59 PM
Default Re: New member. Building D8
Nice work, Fired up. What sort of metal working equipment do you have at your disposal? Even if you don't think your dozer is quite as detailed as some others, I think it looks great. Just shows that sometimes you don't necessarily need a lot of fancy CNC equipment to make a nice functional model.
For window glass, you could always go with some clear, thinner acrylic plate, or maybe some polycarbonate / lexan sheet, cut to size. Maybe make some gaskets out of sheet styrene to hold the 'glass' in place (sandwiched between the cab walls) on both sides, or maybe an aluminum window frame on the inside of the cab wall, slightly smaller then the window opening itself, so that the glass can be glued into that resulting window pocket with a clear drying canopy glue for models.
Old 12-15-2013, 11:43 PM
tracksntreadslou's Avatar
Wow you Build fast and awsome work ..I have been watching from the start and now lookinf forward to some dirt pushing vids ..awsome ..keep up the great work
I was at my local liquidation world and found some very cheap smoked clear totes ..less than an 3/32 thick ..Should work for my grader windowws
Old 12-19-2013, 12:39 PM
Thanks for your encouraging words. All I have far as metal working equipment is a small metal lath. Every thing else I have is for woodworking. Far as glass I picked up some lexan. At a glass shop. May not be pushing much dirt for a while we got 17 inch of snow last week and calling for more this weekend.
Old 12-19-2013, 08:05 PM
Here's the new addition. To my small fleet. I needed something to Haul my dozer. Now to build a deft trailer and a dump trailer. After dozer gets finished.
Old 12-20-2013, 12:57 PM
Well I do not have a lot of time this time of year my shop turns into santas work shop as I usually have some kind of Christmas gift to build. This year it's a fire place. But I did get a half hour and put together my interior I primed it and it's waiting for finish paint. I hope to see my hydraulics the end of this month. Thanks for looking. And merry Xmas to all.
Old 12-20-2013, 09:28 PM
DADSGARAGE's Avatar
17" of snow...so you're saying you just got a little bit snow??!! Yikes!! With that much snow you may wish the dozer was 1/4 scale..LOL
How wide is the blade on your dozer?? And how big is your driveway....
Looking forward to seeing more pics as you build !!!
Old 12-23-2013, 12:40 PM
Blade is 13''. And drive way to big lol. But would stop me from trying if I had the hydraulics working
Old 01-08-2014, 01:10 PM
Still waiting Hydr parts. Hope to see them soon. I did receive a sound modular for it to day and some wheels for my low boy. Not sure about starting the paint until l get the hydraulics in and working just in case something needs tweaked. Hard to find time in shop lately with all this snow. I have at lest 3 feet of snow here.
Old 01-13-2014, 12:38 PM
Default Re: New member. Building D11
Well as I am waiting let's start a low boy trailer to haul dozer. Pic of mock up. 3 axels or 2. I think 3. Can anyone tell me how well or not well the stock king hauler pulls. Dozer will be around 50lbs and trailer weight witch could be 15-20 lbs. any suggestions.
Old 01-13-2014, 05:17 PM
Had a couple hours here's a start for lowboy. Clean it up some later.
Old 01-13-2014, 08:49 PM
A bare stock will pull it ok, but at least 3:1 additional gear reduction would be better control. Lock the rearmost axle.
Old 01-14-2014, 08:51 AM
How do you lock the rear axle the gear reduction is that from rc4x4 ?
Old 01-14-2014, 01:02 PM
I am building this project as cheap as I can here's the first axle. Using threaded rod with long nut on each end passing through 1/2 by 1/2 square tubing
Old 01-14-2014, 01:07 PM
Here's anther view of axel. Like I said building this as cheap as I can I am make the wheels out of hockey pucks turning them on my lath. Still thinking of how to build the goose neck.
Old 01-14-2014, 01:38 PM
Take the axle off the trk, split the plastic case, take the diff apart & there you will see the 3 small bevel gears on the cross. Slide one spider gear off the cross & drop it between the other 2. Reassemble the axle.
Locking the rearmost axle doesn't seem to hamper the steering too much, but does help immensely in pulling in the dirt. Of course 6wd is even better yet & adding Shoe Goo to front 2 diffs is the best for limited slip & great steering control.
Old 01-14-2014, 06:44 PM
Great thanks will look in to it. Here is a few pics of axles installed
Old 01-14-2014, 06:47 PM
Pic of axle pieces.
Old 01-16-2014, 07:23 AM
I am going to put a new duel speed control in my king haule and was wondering if I could use a 12amp in it or should I go with the 25amp. Any suggestion
Thanks
Old 01-16-2014, 08:35 AM
12amp should be fine. I use a Sabertooth 2x12 in my 850 Kenworth and it only overloads it while in high gear towing a load. The truck is around 100 pounds at that point.
