Old 02-17-2014, 10:58 AM
cosworth34677's Avatar
Default Re: Sluggish hydraulics
Originally Posted by Bg416 View Post
I was told to use any antifreeze and the motor sounds like its running at full power
hi i have found with the hrc stuff they are really big on the servo's being set upt just right. i had sluggish running gear for a while. and found that this was the problem, also little giant is right it dose any but, the kit i got seems to work better with a 70% -20% water mix. it seem to bee just thin enought let the hydraulics move free, but slick enough to lub up everything. staight antifreeze beside being nasty to clean up seem to run the pump really hot(it dose anyway)and get sluggish after while.
