Old 06-01-2014, 06:21 AM
gismow's Avatar
gismow gismow is offline
gismow is on a distinguished road
Default Re: Rebuild of a Knight Hauler after a Crash
The cabine
First I bought a new cabine and started to paint with color from a hardware store but the result wasn't as expected.
Some areas are rough and the color is too thick, structures are covered.
But after having a look at the old cabine I saw, that the professional painter hasn't worked correctly. It seems that he didn't use a primer. I could pull the paint of the cabine with a cutter.
Now I had a clean cabine and I decided to start again. It was also needed because with the last cabine I forgot to modify 2 things. The holes for the pipes must be wided for 2mm because the holdings at the pipes are set 2mm too high, error in measuring. In addition not all holes were closed.
So pictures will say mor than 1000 words:
Yesterday I started to paint again, now with primer and colors from Tamiya
Here's the cabine after priming and wet grinding.
Greetinx
Peter
Old 06-01-2014, 06:23 AM
gismow's Avatar
In addition the truck will have a special light feature. To realize this, I created a small platine with an ATMEL ATMega328 chip.It will stear a light effect depending on the speed of the truck.
Greetinx
Peter
Old 06-01-2014, 06:27 AM
gismow's Avatar
An add on for the rear, I created a new pair of mud flap holder (??? correct words ?). They include the blinker.
Greetinx
Peter
Old 06-01-2014, 09:52 AM
rsd53 rsd53 is offline
rsd53 is on a distinguished road
If I under this correctly, this device will alter the voltage signal going to the steering servo. As the truck speed increases, the maximum voltage to the steering servo decreases.
