RCP’s Aluminum Gravel Boxes and Accessories Welded aluminum dump boxes and more |
Super Dumper
Re: Super Dumper
Why so many axles?
#shouldhavebeenatrailer |
Re: Super Dumper
#becauseyoucan
Unique and interesting truck
Re: Super Dumper
Bigford, Do you intend to have the rear axle hanging off the backside of that thing?
Re: Super Dumper
Re: Super Dumper
So the scale box length is 24 foot?
Re: Super Dumper
Awesome job as always Reg Well earned break!
Re: Super Dumper
WOW! Just simply...... WOW!
Outstanding build |
Re: Super Dumper
Re: Super Dumper
I'm anxiously awaiting to see how well you like that hyd multi stage lift ram for the dumper. I've thought about one, but am leery of pulling the trigger on the purchase. I just haven't seen them in use enough to know for sure how good they are.
Re: Super Dumper
It's a nice cylinder seems strong enough and with a good
Pump it will definitely lift any thing I toss in the box. I think reg said it a 45° dump angle could have used the 550mm cylinder instead https://youtu.be/S9G3nc-i3mQ Last edited by bigford; 12-21-2017 at 06:34 PM. |
Re: Super Dumper
Any idea how much weight it's capable of dumping?
Re: Super Dumper
It should lift a lot given the bore size of the first stage. Of course that all depends on the pump used but I don't think it will have issues dumping a heaped load.
With this cylinder it has about a 40 degree dump angle. Not super steep but enough for gravel or dry dirt I think. |
Re: Super Dumper
Off the rcbmim site. Take it for what it's worth
Capacity : 80 (ML) Rated pressure : 2 MPA Maximum pressure : 5 MPA Theoretical Thrust :Theoretical lifting force 110KG (first section |
Re: Super Dumper
110KG, first stage, so slight loss(es) as each stage raises......I'd bet it'll lift 24-30 pounds with no problems, if not more.
Re: Super Dumper
Cheer’s, Neil. |
Re: Super Dumper
Re: Super Dumper
nice did you get the lift system working yet?
MACK
"The Greatest Name in Trucks" |
Re: Super Dumper
that thing is looking great
Re: Super Dumper
Looks fantastic!
