Old 09-28-2017, 01:41 PM
FabOne's Avatar
FabOne FabOne is offline
FabOne is on a distinguished road
Default Re: Liebherr LR634 Track Loader HYDRAULICS
I'd go with the Leimbach hyd system, much more compact than the Premacon kit with Jung pump & Meinhart valves. For only two functions, you'll get plenty of flow & power from Leimbach too with 2mm plumbing. Plus with an esc on the pump motor, start/stop on Leimbach's small brushed motor is possible; whereas the Premacon kit would have to be in constant motion to prevent esc freeze.
THANKS Joe! Great explanation in regards to the size and operation of the two units.
-Terry
FabOne
NW Ohio
