| Metal forming & tools If it bends,twists,welds,cuts & turns metal.Post it here |
#81
Ditto. Except my mom was never into the "soaps". But saw enough of the tv ads for that slogan to have burned a permanent entry in my brain.
#82
Houston, we have a problem. How can I ensure that the X axis rails are parallel to each other? Just so we're all reading from the same page, let me refresh your memory of what this thing looks like.
Starting in the lower LH corner we have what I am going to call the west side, because that's the way the machine is actually oriented. The X axis rails are the longer set of rails running east-west, with the Y axis being the shorter set of rails that run north-south. Keep in mind that the gantry is fixed and the bed moves east and west along the X axis, The spindle moves north and south along the Y axis rails. The magenta colored objects that are 50mm from each corner of the frame are the standoffs that hold the frame about 6mm off the base. Those standoffs are there, because there's a lump in the base. As near as I can tell, using the edge of a carpenter's square for a straight edge, the east, north, and west edges of the base are flat. The lump is about 0.008"-0.010" thick, and is centered about 100mm from the south edge of the base, and about 1/2 of the length of the machine from the west end. Except on the south side, I know those standoffs are in areas that are flat. The 6mm gap should allow the machine frame to bridge the lump, so the top of the frame should be flat to the east, west, and north sides of the base. So hopefully, this will allow me to ignore the lump. So here M'Lords, is my clever plan, at least for the X axis alignment: 1 - I'm going to level the east, west, and north edges of the base. I've got a precision level, it's not a great precision level, but it's got to be better than a carpenters level. I've got some leveling feet on order that should make that job a little easer. 2 - After the base is level, I'm going to level the frame to the base. I'll level it both north-south, and east-west, that'll ensure there's no twist in the frame. I'm hoping it will already BE level, but... Hope for the best and plan for the worst. If the frame isn't level, fixing that will involve shimming it level. Since everything else is somehow related to those side frames, getting them true to the world will make life easier for Future Don. I got some 5/16" thick float glass that is used to hone wood working tools "scary sharp", this and my 1-2-3 blocks should allow me to bridge over the bed and check that the frames are level - both north-south and east-west. JBWorxStudio uses the float glass to tram in the spindle of his CNC router, it should work for this too. 3 - Next will be checking that the rails are level, this will tell me if the vertical centerline of the rails are parallel to the top of the frame. I'm REALLY hoping that the rails will be level to the frame, since the mounting bolts for the rails use the 2 side slots in the 2040 side frame extrusions. There may be a little wiggle room there, but not a whole lot of it. 4 - Next on the hit parade will be checking the bed, The bed should be level, it does ride on the X axis rails after all. But, those linear bearing mounting brackets were fabricated early in this project, before I knew how critical attention to detail REALLY was. If they aren't level, I'll probably have to slot the mounting holes for now, and make new brackets when I get this thing operational. I also need to be sure slots of the bed are perpendicular to the side frames. a 6" square fill do for now. Once I've got the bed level, I can start the process of getting the Y axis rails aligned. |
#83
The leveling feet I ordered showed up this afternoon, so tonight's task was to install them. I can't complain too much about them, the parts are fairly high quality and I got 2 sets of 4 for 20 bucks US. There is one thing I did complain to the seller about, the stamped level adjusting wrench. That little toad is 14mm, the hex on the leveling foot is 12mm, and the locking nut is 13mm. If I can't find a suitable wrench, I guess I'll have to make my own.
I thought these leveling feet came with an anti-skid pad for each foot, but they didn't - guess I'll have to get some rubber washers or similar and make my own. These feet have a 50mm OD pad, a M8x50mm leveling screw, an M8 locknut, and a 4 prong tee-nut suitable for driving into wood. These were "heavy duty" furniture leveling feet/glides after all. The barrel of the tee-nut measured a little over 0.370", so I drilled the holes for the barrels at 21/64", about 0.391". I put the tee-nut in the hole, smacked it with a hammer to mark the locations of the prongs, drilled a 1/8" pilot hole for each prong, and used percussive persuasion to install them. (I hit them with a big hammer until they stopped moving.) This is what the feet look like when installed. I then started the leveling process, the level is on the north side now. Having never used a precision level before, I quickly discovered that there was a reason they put a standard level perpendicular to the precision level. You REALLY want to get the bubble centered in that standard level BEFORE you try getting the precision level's bubble centered - makes a big difference in how it reacts. That's 2 sheets of legal pad paper used a a shim to get it level side to side. When I was leveling the east side, because of the small ledge I had to work with, I clamped the level to the machine endplate. The base of the level is wider than the top so I had to use a washer between the top of the level and the endplate, as a shim to keep the side to side bubble centered. Right now I'm thinking it probably would have been a good idea to go around this thing with a regular level first, just to get things close. |
#84
Last night I went around the base several times with the precision level, it's as level as it's going to get. I thought that I had leveled the base of the workbench when I installed it almost 20 years ago, if so - I did a really crappy job of it. The base of the machine is about 400mm x 600mm. from the NW corner to the SE corner of the base there's a 6-8mm difference in length of the adjusting stud. The workbench top is flat, it's just not level. Eventually I got the base close enough to level that the paper shim was no longer needed to have the cross vial's bubble be centered, I could just set the level directly on the base.
Next I check the to see that the frame is level, and then it'll be on to the X axis rails. |
#85
some real precision going on in here. Now just remember to not move the machine.
#86
Blender:
I went around the base leveling feet a couple more times, to get things dialed in. All the while wondering if this was a gigantic waste of tine. The more I dug into it, the wonkier the base was looking. I thought the bottom side of my base was flat, but it's actually concave, in both the E-W and the N-S directions. The bottom of the sides are fairly flat compared to the center. And tops of the East, South, and West sides are fairly flat. The top of the North side has a noticeable hump in it. The base itself is not a consistent thickness. The West side is 0.2mm thicker on the North side than it is on the South, the East side has a similar taper. The South side is 0.2mm thicker on the East side than it is on the West. The North side is 0.2mm thicker on the East side than it is on the West. Which makes the NE corner 0.4mm thicker than the SW corner. Just for shits and giggles I got out the float glass plate and my 1-2-3 blocks to check if the side frames were level. N-S they were level, but E-W they were not. That required 3 pieces of paper under the West leveling feet as shims. Tomorrow I cut some shims for under the West frame mounting standoff and fix that problem. From here on, everything will be aligned to the side frames - in some way. It was my intent all along to have the base sitting flat on the bench, probably on a rubber mat for sound deadening. After I get things aligned: the X axis, the Y axis, and the bed - I plan on putting a 1-2-3 block under each corner of the base and see if any thing changes in the alignment. That'll tell me if I can go back to Plan A, or if I need to tolerate that gap under the base and everything that is going to wind up hiding in there. |
#87
Well...
Progress on this thread was slow enough already, but starting tomorrow it'll get even slower. Tomorrow work on my new garage starts, or at least the demolition of the deck where the new garage will be located starts tomorrow. It's going to be a busy summer. |
#88
Well isn't that SPECIAL. AVG just started blocking me from RCT&C - because they say it's UNSAFE!
So now whenever I want to check in to see what's going on here... First I have to tell Microsoft to shove their "UNSAFE" opinion where the sun don't shine. AND THEN, I have to tell my anti-virus software to sit on it and spin for a while. |
#89
I use Firefox and will get the same type of message from time to time. I just select proceed anyway and get right in. Then until I clear my history it remembers that I allowed it and doesn't try to stop me anymore. I use eset as my firewall and nasties blocker and it doesn't have a problem with the site.
Making any progress on your cnc or too busy on everything else? |
#90
Same with Chrome.
The AVG anti-virus was nastier, it would kill the connection to RCT&C - claiming it was a dangerous and malicious site. At first I'd disable AVG, check in, then re-enable AVG when I was done. But, I knew that practice would eventually come back to bite me in the butt. So I started looking to see if there was a way to tell AVG to ignore that a particular site was "UNSAFE". Turns out that buried under a couple of layers of menus is a section called Exceptions. There you can add the URL of any site, to tell AVG to make an exception and NOT to put that site on the Naughty List. No progress to speak of on the CNC, been working on the Cub Cadet. It's an early 70's International Cub with the wide frame. It doesn't have any hydraulics and no rear lift. I've got a front blade, but didn't have a scraper. So I've been adding a rear lift kit to the Cub, the kit's supposed to fit a wide frame Cub. I think they meant the lift kit would fit a wide frame MTD Cub - not my wide frame IH Cub. It put up a fight, and I've got a lot of left-over bits - but the lift kit is solidly attached to the International Cub's frame. I needed to add a couple of new 5/8" holes to the lift kit's frame. I don't have any bits that large, and the frame is bulky enough not to fit in my drill press. However...there is a shortcut. I'd been lusting after a mag-drill for some time, so last winter when I stumbled on a single speed Vevor mag-drill kit with 11 annular cutters for $90 - I bought it. I REALLY wanted the variable speed version, but they were another $100. So I did the next best thing, I also bought a $20 variable speed controller kit for the drill. All that stuff sat waiting to be combined and used, I'm a faithful follower of the Procrastinator's Oath - Never do today what you can put off until tomorrow. I had previously determined that there was plenty of room inside the drill to install the speed control in the drill. I'm actually kinda glad that I did decide open it up and rewire it - it was a mess. The 5A quick blow fuse was feeding both the magnet electronics AND the 500W motor, and I'm not sure that the indicator lights in the switches would have worked. They DO work now, and the control panel has a variable speed knob on it for the motor. The real reason I rewired the drill was that I wanted to be SURE the motor was the ONLY thing affected by the variable speed. When I worked at Quaker we burned up 3 conveyor motors before we figured out that motors with an electric brake WILL NOT release the brake if you try feeding said brake from a VFD. Now, I need to put the IKEA box blade kit together, it came in a flat pack so it's gotta be IKEA - right? I ordered that stuff late last year and I'm just now getting to the point of needing it. When I opened the IKEA kit yesterday I found that there's no cutting edge for the blade, I'll have to see if I can find one. Maybe I can get lucky and make the scraper blade from the Cub snow thrower work. I hate that thing and don't use it anyway - it's the original spinning wheel of death. So, if I can force that blade to fit - it's gonna get used. Last edited by ddmckee54; 06-10-2026 at 05:12 AM. |
| Thread Tools | |
| Display Modes | |
