Old 04-21-2025, 09:49 AM
Default Re: TH407C Telehandler 1:14 scale
Very awesome to get to get to see this off the bench and moving!
Mmm, counter-steering. Could you set up a way to toggle a mix to also allow Crab steering?
If you don't have any tire scrub on turns, you're already doing way better than fullsize JLG bucket lifts
Old 04-21-2025, 10:50 AM
Blender's Avatar
Blender Blender is offline
Originally Posted by ddmckee54 View Post
Since you have a gearmotor for each wheel are you doing any mixing to get some differential action?
Originally, yes. Now I'm going to skip all together. Less wiring and the inner motor is able to bog down to match speed.
Crab steer is a must! It should be pretty easy to setup on the radio. It's the feature I look forward to the most when placing stuff with the forks. I'll do a front steer only as well for high speed travel.
Old 04-27-2025, 10:18 PM
Blender's Avatar
Worked on the tilt a bit. Had to turn a bunch of tubes from stainless. It was terrible, but I got it done. These parts were reworked from original design to accept Lesu implements. Less stuff I have to build and some commonality to my small wheel loader.
Old 08-09-2025, 01:48 PM
Blender's Avatar
Progress dump one what I've accomplished while the site was down:
Machine is fully functional now. Wiring is mostly hanging out the side before I condense it all. Hydraulics are really smooth although slightly slow. Since I'm only on 2S lipo I should have a slightly higher kv pump motor. Not going to change anything. Works great as it is.
Did add a step up voltage converter to get a steady 12V for the drive motors. Woke them up and make better torque. Will still swap in a set with deeper reduction.
Crab steer is my favorite feature when placing a barrier inline. A fun little machine
Old 08-09-2025, 05:50 PM
Really looks good, great progress. Am glad to get to see more.
Old 08-17-2025, 11:25 PM
Looks like really good use of the site downtime!
Great looking construction fleet
Old 08-18-2025, 12:01 AM
Blender's Avatar
Thanks guys. I'm really happy with this machine. I've been slow to start painting since it's too much fun to play with.
Old 05-16-2026, 07:18 PM
Blender's Avatar
Decided it's time to clean up the lines for the tilt cylinder. They have been dangling out the back. Going to route hard lines to the tip of the outer, then use soft lines inside the hollow for the length change. Previously was all soft lines inside the cavity and they get kinked.
This means I need to re build the entire outer boom. I'll use this opportunity to seal up the back of the chassis too. Everything will get painted green/grey before reassembly.
Input is 2mm OD brass hardline to M3 banjos from other fittings to barbs for 2mm OD soft line.
Waiting on a gasket material that fits between the brass blocks
Old 05-17-2026, 06:05 PM
Very interesting. Don't thing I've ever seen a fitting like that before. What is the route the oil takes to get from the hard line to the hoses. I assume there is a hole through the shoulder of the bolt to the hole down the length of the bolt like most banjo fittings. How does the oil flow out of the bottom of the bolt and into the hose fittings? Gap left between the bottom of the bolts and the bottom of the inside of the hose fitting block?
Old 05-17-2026, 07:55 PM
Blender's Avatar
You are exactly right! Banjo style hollow bolt that doesn't quite reach the bottom of the hole. Here's my test fit before soldering the barbs. Off the shelf fittings were all too big, so I made this overly complex solution.
Hard lines turning out good. Inner/outer fitment is better than the previous version too. A little body filler is on to get ready for paint.
Old 05-18-2026, 06:16 PM
Very ingenious. Filing that away in my how-to binder for future use. Looking really good.
Old 05-21-2026, 12:44 AM
OK Blender, nice job on the hard lines, but it's time to get out the crayons and the pencils. How are you routing the soft-lines inside so they can't kink? Every scenario that I can think of involves either a 180 degree bend in the soft line - that could kink; or a swivel fitting to eliminate the sideways load on the soft line as the boom extends/retracts.
Old 05-21-2026, 10:09 PM
Blender's Avatar
It's mostly a space thing. Previously I needed 2 180 degree bends. Inside the cavity. Now one of the runs Is external and a 180 bend in in the crazy brass fitting. Less hose in the same size cavity.
Old 05-28-2026, 03:40 AM
Blender - way off topic, but do you follow zulu dockyard's YouTube channel? Zulu dockyard
About a year ago he started building a 1:33 scale all metal tugboat, it's mostly made of 0.020" sheet brass that he hand forms and solders together. It's been interesting watching how he forms some of the parts. He's working on the superstructure now.
Old 05-29-2026, 12:26 AM
Blender's Avatar
I left youtube back in 2020. Don't watch anything besides the occasional embedded video on other sites. Ive causally tried hand forming thin sheet metal. Didn't turn out well. A different skillset which i just don't have.
Would be great to make complex metal parts with no tooling.
Got some color on the boom and chassis. Most wet sanding complete. Now to rewire and re plumb the whole thing. Then I gotta make more decals.
Decided to re model the engine cover. Needed to be body worked and repainted anyway. Original was fine, but I wanted to add a little more subtle swoopiness.
Currently Active Users Viewing This Thread: 16 (0 members and 16 guests)
Copyright ©2000 - 2026, Jelsoft Enterprises Ltd.
