Old 08-06-2024, 06:21 PM
Default Re: Chevy K30 U-haul Maxi-mover 1973-75
I have lived and worked all over the country and I have never seen a U-Haul horse trailer. Any idea where those photos were taken? For the record, I absolutely hate U-Haul trailers. The wiring in them is always a complete rats nest and never works right.
Old 08-06-2024, 11:16 PM
Zabco, i hadn't noticed them either, but i'm also not in horse country. i'll show my work
My phone won't show exif data on an image, so i don't know where it was taken. I found those trailer pics on Reddit, with a couple people saying not-fake, but old and very rarely used. Then while searching for more horse trailer info i found a total of 3 pics, all of the same trailer! (Fleet number 3666 SO 8133, which has a Georgia plate in a pic)
That Georgia farm plate is odd since almost all of Uhaul fleet is plated to Arizona
I mean is it weirder to go around taking pics of fleet vehicles to post on the internet, or weirder to paint your own outfit in a rental livery? Then several horse owner sites popped up mentioning 'renting a u-haul horse trailer' maybe it's a thing, could be the "All 'facial tissue' = Kleenex" thing, could be search engine optimization bs...
Well, i still liked the idea and thought that seemed plausible as close enough to real to make a toy fake one? So working off the rental company "seems to have run a few of those", and that the toy company "could have produced those with existing parts" was close enough for my destructive tendencies.
https://www.uhaul.com/FrequentlyAske...owing-Rentals/
Then since you asked, it looks like there are only 5 locations in California and New Mexico that have horse trailers available as of 2021?
Third pic
Don't worry instead of an inop rats nest of wiring, none these are even getting lights! Just some rhinestone reflectors.
Old 08-11-2024, 09:16 PM
Blender's Avatar
Blender Blender is offline
Tracking down where the actual horse trailers can be rented is awesome. I expect license plate and phone number of the branch on the finished trailer.
Old 08-12-2024, 12:50 PM
Haha, yeah Blender i spent some time on that one... i mostly hack up old toys and do weird car things to make me smile, i don't really do "exact replicas". I haven't even figured out what model each trailer is trying to replicate. If gets people to notice and smile, it's usually close enough.
I may be neurodivergent , but not quite THAT flavor.
Well, how about we fake something they DO commonly rent?
It should get the shorter Uhaul tires once the chevy is mounted up on WPLs
Trashing a Boat Trailer would probably have been the better way to go for a car-dolly since it was production, and has the baby fenders. I haven't seen any of those go cheap, and I had a frame offcut from this rc and a fire ladder truck axle
Uh, ok, but isn't there supposed to be "A Truck Build" going on?
Some carrier bearing crossmembers are printed, with bearings, some body tab clearances got hacked into frame
https://cults3d.com/en/3d-model/gadg...ong-wheelbases
These use the same bearings as the axles
Old 10-11-2024, 09:54 AM
It was finally time to get the chassis moved off the mockup axles. Decided it needed some wpl 'potmetal' axles, and might as well get a set of brass Differentials instead of the steel Spools those come with. My thinking was that a Box truck probably needs turning radius more than 4 wheel traction or durability.
Get in the zone, Advance toy parts
Oh oh oh, oh Napa.
We didn't need liftgate service, so they were willing to send a parts-runner out to the garage.
These brass Differentials felt crunchy, so i spent a while pushing inward on axles while rotating to help wear in the gears. I plan to run them for a while, then open to clean and lube. Everything needs to come apart for threadlock once it's more final anyway, so that shouldn't be a problem.
To make up for the larger housings for spiders, these diffs come with a shorter pinion than used on wpl spools.
I've been looking for a D-wheel dually conversion rim with the convex face.
Chevy and GMC grille
https://www.etsy.com/listing/1599115...original-style
https://cults3d.com/en/3d-model/gadg...conversion-kit
https://makerworld.com/en/models/374...42?from=search
Rally wheel center in d12 structure
https://youtu.be/l5PnA-2UCSM?feature=shared m2.5x20 hardware to stack wheels
https://www.thingiverse.com/thing:6174132 Squishy tire with d12 steelie profile wheel
Old 04-17-2025, 07:20 PM
Remade more carrier bearings, stabilize filled those with jb weld.
Modified the rc-frame and toy-frame to sit better. Modified the box and rc-frame to sit better. Modified the cab front mounts.
Now i can pull the box off the truck and have a cutaway truck, so it could become a ramp-deck or something?
Yo dawg, i heard ya like driveshafts!
3 piece rear drive, plus putting in a front make this a 'K' truck instead of a 'C'.
You may have heard me say i want a lot of springs, but what i actually said is Bring Me All of Your Springs.
Bad chrome is weird on fleet truck, but thought that front end still needed some more colors
But those diff pumpkins needed WAY less red! I'm still ok with red trans and knuckles though?
So how's that ride height look compared to before YOU RUINED IT?
I've been looking for a design of a 'Budd' style D12 dually rim for 2 of the d12 rubber tires, but no luck yet. All the duals seem to be for B or C truck tires.
Old 11-07-2025, 10:10 PM
The aluminum Dually wheel set i found with 'D' truck tire height have the wrong offset to work with the axles and rear box.
Been throwing some paint at the trailers.
Found a broken aluminum nylint 'Car Top Carrier' for my AMC Pacer.
Since this won't fit dually wheels, but they would fit a Ford COE truck with a wrecker service bed. I've kinda been kicking around the idea of a vehicle with something using WPL parts for like a Dig (shiftable 2wd / 4wd / lock axle) function, but hadn't come across any good ideas. Mostly wanting it for a Part-time 4wd feature, probably don't really need the actual Dig function.
https://youtu.be/XAe3YX4vKQc?si=5Xzy_jZMbBxIBfso
Even with all the excessive driveshaft length available to install one here, Uhaul probably isn't the right car to put a similar unit on. This trucks long rear overhang and bad departure angle probably would NOT work well behind a Sling-back Wrecker that those wheels do fit.
Old 01-22-2026, 08:05 PM
The guys at the Wrap Shop said the graphics were ready, so we had a guy take the truck over to freshen up the livery a little.
It's not 100% Nylint original, or even 100% U-haul livery. It should fit about the era they started adding some differences to the fleet, but still before the white boxes with big splash graphics. So i figured i might as well add "Sammy U" to the cab doors.
https://www.youtube.com/watch?v=aZIoAj3mI6I
Some ways to design and print Rolly doors
Currently Active Users Viewing This Thread: 14 (0 members and 14 guests)
