Old 12-31-2013, 04:58 PM
kenobi kenobi is offline
kenobi is on a distinguished road
Default Re: Volvo A40F articulated dumper
Originally Posted by Manfred View Post
Leave it with the 4 Lipo cells. The problem with the CTI cylinders is that the electronic end stop does not always work properly. Take on each side O-rings, so that can not run on end stop while steering the cylinder. I even installed each 2 O-rings on each side with me.
Manfred
Do you mean O rings installed on the piston shaft so that each shaft can not be pulled completely into the cylinder?
Also is the Thor 2 BCD speed regulator ESC good enough or do you have better experience with another ESC type for parrallel CTI cylinders
Thanks for the great advice.
