Old 12-31-2013, 04:58 PM
kenobi kenobi is offline
kenobi is on a distinguished road
Default Re: Volvo A40F articulated dumper
Originally Posted by Manfred View Post
Leave it with the 4 Lipo cells. The problem with the CTI cylinders is that the electronic end stop does not always work properly. Take on each side O-rings, so that can not run on end stop while steering the cylinder. I even installed each 2 O-rings on each side with me.
Manfred
Do you mean O rings installed on the piston shaft so that each shaft can not be pulled completely into the cylinder?
Also is the Thor 2 BCD speed regulator ESC good enough or do you have better experience with another ESC type for parrallel CTI cylinders
Thanks for the great advice.
Old 12-31-2013, 05:42 PM
Manfred's Avatar
Manfred Manfred is offline
Manfred is on a distinguished road
Yes at the piston shaft and the threaded rod.
The Thor is o.K.
Another option is this one. http://www.cti-modellbau.de/CTI-Schaltmodule/-154.html
With limit switches, you can limit the way and with this switch module you switch on minus the knob. If the limit switches are set correctly, the cylinder no longer drive fixed. I would recommend it but only with the O - try wrestling.
Manfred
