Old 04-09-2016, 12:38 AM
Rakthi's Avatar
Rakthi Rakthi is offline
Default Re: ScaleART - Assembling a MAN TGX/XL 6x6 tractor & Trailer
Hi Prop, yup you are right, the red still shows the details. If you compare the pictures to the black one from the Arocs, big difference.
Re-assemled some bits today.
The heavy duty coupling at the front bumper. Couldn't get the pin in due to the paint so had to file out the openings in the coupling. Good thing I didn't paint the bits I left black.
Also re-attached the fuel tank supports. (fuel tank and straps will be black too)
Not much done, but time consuming because I had a "senior moment" about where I put some of the bits ...
