Old 04-09-2016, 12:38 AM
Rakthi's Avatar
Rakthi Rakthi is offline
Default Re: ScaleART - Assembling a MAN TGX/XL 6x6 tractor & Trailer
Hi Prop, yup you are right, the red still shows the details. If you compare the pictures to the black one from the Arocs, big difference.
Re-assemled some bits today.
The heavy duty coupling at the front bumper. Couldn't get the pin in due to the paint so had to file out the openings in the coupling. Good thing I didn't paint the bits I left black.
Also re-attached the fuel tank supports. (fuel tank and straps will be black too)
Not much done, but time consuming because I had a "senior moment" about where I put some of the bits ...
Old 04-24-2016, 04:34 AM
Rakthi's Avatar
Got around to actually doing something on the MAN again.
Had noticed that the fuel tank supports were not lining up. By moving the left one over to the right, it is not longer really on the more narrow part of the frame. So took the spacer out and replaced it with regular nuts.
That taken care off, time to do the bowden cables for the rear and front diff locks.
First I needed to bolt the holder for the servo that will operate the rear diff locks to the frame again.
Also needed to bolt a holder for the rear cable hose to the frame. As with the Arocs, I drilled the 2mm hole out to 2.5mm to facilitate inserting the cable.
The run of the cable is pretty straight forward.
The first rear axle still has the "old style" guide on the diff. So needed to loosen the screw so I could get the cable guide in there.
Wasted some time by trying out a couple of variations of running this cable to see what would work best.
Ended up with bolting the front axle back to the frame. Didn't get around to doing the bowden cable for this one. This will be a more interesting exercise since the servo goes into the fuel tank.
Might take the cable guides back out and paint them red or black, that way they don't stand out too much.
Also been painting some other bits and pieces. Was surprised to find out that the fifth wheel is cast bronze.
Old 04-25-2016, 01:35 AM
Rakthi's Avatar
So after yesterday's post, took the cable stuff of again to paint it black. Was not too happy with the way I had them running either, the bends should be much smoother so there is less stress on the servo.
Painting the cable guides black didn't work out too well as you can see on the pictures. Will need some retouching.
Since I had the cable out, I made the hole through which they go to the servo holder a bit larger.
I also drilled one of the holes in the frame out to 3.5mm so I can run the servo cable through it to the other side side the frame.
To run the cables a different way, I needed one more clamp to go on the frame
As you can see the clamps have no thread near the top. ScaleART provided 2.5 mm nuts to go there. Too lazy to search for them, so I just drilled out the thread in a 2mm nut instead. Same result.
Blue arrow is the newly installed clamp
Ran the cable for the front axle first. I also installed the rear prop shaft to make sure nothing gets tangled up.
Not too happy with this way either. The bowden cable gets hung up in the frame hole. And the clamp on the other side of the frame is not in the right location. So dumped that idea.
Here both installed in a way they have free movement, don't rub too much and have nice big bends.
In the following 2 pics you can also see the amount of movement in the prop shaft. I did put grease on the shaft, was a bit tight after painting. Also put Loctite on the grub screws holding the prop shaft to the axles.
I also removed the clamp I installed yesterday since I didn't need it.
So now to the front axle ... Had to install engine/gearbox/propshafts to check for interference with the cable.
Cable can run like this
This is where we are at now ...
Seems that before I can do the servo in the fuel tank, I will have to add some more bits and pieces to the frame to know the almost exact position of the fuel tank. Also time to dig out the electronics to set the servos in "neutral" so I can start cutting the actual cables.
Tags
man tgx xl, scaleart, trailer
