Old 04-13-2016, 09:13 AM
gauthib12 gauthib12 is offline
gauthib12 is on a distinguished road
Default Re: Morpower 3 way valve
Hey Bigford thanks for the link..so you have a triple morpower block?. there is not allot of mechanics, the valve is pretty simple..I can't figure out why the oil is coming out both lines as soon as I turn the pump on...I didn't nic the rings...even when I turn the screw on the bottom tight for no flow I am still getting oil out both lines..?? Albeit less but should be 0! I tested the 3rd port and with the valve centered in neutral there is no flow...which when rotating the valve works as supposed too, same as on number 1 port...I am perplexed? I emailed morpower again...
