Old 06-25-2016, 09:13 PM
Doggy's Avatar
Doggy Doggy is offline
Doggy is on a distinguished road
Default Re: Tamiya bolt on reduction gear
Trewq is testing the the unit to its limits. A true test pilot
And today I worked on AWD GRU unit. This version has front output on the bottom, and I also will try to make other version with the output a bit higher on the side. With this design I can also change front/rear gear ratio independently, as my new front axle will be 38-14, and rear tamiya axle is 40-15.
