Mechanical tech This is for the mechanical parts of a model. Gear reductions, Axles, Transmissions, General drive line |
View Poll Results: Would you buy this if it went into production? | |||
Yes I would buy a metal version |
13 | 34.21% |
Yes, but I would like a cheaper plastic version |
18 | 47.37% |
No, there are better options out there |
7 | 18.42% |
Voters: 38. You may not vote on this poll |
Trewq is testing the the unit to its limits.
![]() ![]() And today I worked on AWD GRU unit. This version has front output on the bottom, and I also will try to make other version with the output a bit higher on the side. With this design I can also change front/rear gear ratio independently, as my new front axle will be 38-14, and rear tamiya axle is 40-15. ![]() ![]() ![]() |
Looks almost like a Tamiya F350 3 speed tranny except that the motor is reversed.
LYNN |
Tags |
3speed, gearing, reduction, tamiya |
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests) | |
