Thread: Stahl Dozer
Old 12-30-2010, 10:58 PM
Default Re: Stahl Dozer
"all the way out"? English is not their native tongue, you have to be much more specific. Total length at extended stroke. I'm thankful that their able to communicate with us at all!
When buying hydraulics, what Stahl or TTM or Wedico sells is made by Leimbach and this is their www addy http://www.leimbach-modellbau.de/start.html
Scroll down left header to Hydraulik, fourth down Zylinder
(K) is bore
(B) outside cyl dia
(L2) length of retracted cyl
(HUB) stroke, add that to L2 for total length extended
Technische Daten:
(K) (B) (L2) (HUB)
H0725 7 mm 11 mm 58 mm 25 mm 34,6 N 28,3 N M3
H0750 7 mm 11 mm 83 mm 50 mm 34,6 N 28,3 N M3
H0775 7 mm 11 mm 108 mm 75 mm 34,6 N 28,3 N M3
H07100 7 mm 11 mm 133 mm 100 mm 34,6 N 28,3 N M3
As you can see, they don't stock that specific length extended stroke. But if that's exactly what you want, they will custom make it for you at extra cost.
My Cat colored dozer uses 7x50 and the JD dozer has 7x25 for tilts.
