Thread: Volvo A40F
Old 07-10-2017, 12:47 AM
Default Re: Volvo A40F
Hey awesome work!! Really!! Do you have a vacuum table? I see the mat material and I know one of the companies uses that material for vacuum fixtuerimg. If so do you like it? Been debating on vacuum vs outsourcing flat parts. Double sided tape has been working but pita to remove!!
Yes I have a vacuum table and at it's best it is great. But when machining a thin materials the mill cutter tends to lift the plate and then it comes loose. By hand you can't move the plate you are machining sideways, but when you lift a corner it's quite easy to detach. I usually run in to problems with under 1mm thicknesses.
