Old 07-09-2017, 07:54 PM
Cooper's Avatar
Cooper Cooper is offline
Default Re: Volvo A40F
Originally Posted by Hemi1966 View Post
I did some brass work with the exhaust system. I think most of you guys would do these with 3D printer, but as I don't own one yet, brass it is
Hey awesome work!! Really!! Do you have a vacuum table? I see the mat material and I know one of the companies uses that material for vacuum fixtuerimg. If so do you like it? Been debating on vacuum vs outsourcing flat parts. Double sided tape has been working but pita to remove!!
Old 07-10-2017, 12:47 AM
Yes I have a vacuum table and at it's best it is great. But when machining a thin materials the mill cutter tends to lift the plate and then it comes loose. By hand you can't move the plate you are machining sideways, but when you lift a corner it's quite easy to detach. I usually run in to problems with under 1mm thicknesses.
