Old 07-24-2017, 10:15 PM
Default Re: Flysky fs-i6 work for us?
That's interesting, and idea what the problem was?
After this post had several hundred views and no replies, i picked one up. I've seen them in background of several workshop shots of builders i respect. All the reviews were pretty good.
So far, I've had good luck with it. The setup menus take a while to get used to, cancel to accept changes, ok to cancel. I haven't done the throttle stick change since i can't get banggood to take my money. It's just running a stationary Dragline crane for me.
The 2 of 3 gear trans problem sounds like you need to play with endpoint adjustments. If the radio you actually like won't do it, check out a "servo stretcher" it goes between the rx and shift servo.
