Old 05-24-2020, 10:10 AM
Default Re: HIAB X-HIPRO 1058 loader crane
I got the parts for the extension cylinders done. The o-ring grooves on the cap for the piston rod sealing were quite difficult to machine as the hole diameter is only 4 mm. My grooving tools minimum hole size was 4,1 mm, so I had to do some grinding to get it fit.
I also got the rest of the cylinder brackets machined.
