I got the parts for the extension cylinders done. The o-ring grooves on the cap for the piston rod sealing were quite difficult to machine as the hole diameter is only 4 mm. My grooving tools minimum hole size was 4,1 mm, so I had to do some grinding to get it fit.
I also got the rest of the cylinder brackets machined. ![]() ![]() ![]()
Great detail and precision!
Big iron is awesome! |
Tags |
hiab, loader crane |
