Thread: Charging jack
Old 07-25-2020, 04:52 PM
Default Charging jack
To install a charging jack can I simply go to the "off" side of the on/off switch and solder in a charging jack. I assume with the switch off the rest of the circuit ie the truck would be isolated from the charging voltage is that correct or there something else that needs to be done.
