Old 07-23-2012, 06:11 PM
Default Re: PFB's Vario JD 850D
A tamiya rig will certainly pull 80lbs, but to try to carry 80lbs too ? You'll want to replace that plastic 5th slider plater with a metal one.
Originally Posted by Tamiya Cowboy View Post
We hauled Dirt Pushers dozer around at indy with them plastic parts and did not break anything and it weights in at 110 I think Joe said..
He'll be fine for a once in awhile pull around but for a every day use you might want to beef up the 5th wheel plate . With Nate's set up he only has statically 40 # on the truck . It's the dynamic loading you need to worry about whereas , I highly doubt you will be pulling it around on uneven ground/roads at a high rate of speed Joe's D10 pulls real well on wheels but try to drag it hitched to the 5th wheel (not that we would ) looks good Nate , now I wana see a vid
