Originally Posted by Lil Giants
A tamiya rig will certainly pull 80lbs, but to try to carry 80lbs too  ? You'll want to replace that plastic 5th slider plater with a metal one.
Originally Posted by Tamiya Cowboy
We hauled Dirt Pushers dozer around at indy with them plastic parts and did not break anything and it weights in at 110 I think Joe said..
He'll be fine for a once in awhile pull around but for a every day use you might want to beef up the 5th wheel plate . With Nate's set up he only has statically 40 # on the truck . It's the dynamic loading you need to worry about whereas , I highly doubt you will be pulling it around on uneven ground/roads at a high rate of speed
Joe's D10 pulls real well on wheels but try to drag it hitched to the 5th wheel (not that we would
) looks good Nate , now I wana see a vid
