Thread: CAT 374D L
Old 01-26-2013, 01:39 AM
Default Re: CAT 374D L
Originally Posted by tracksntreadslou View Post
When your milling out the smaller holes can you pretty much cut through the thinner guage material or do you have to make multi passes with those fine bits..Feed rates make a difference as well? Thanks Ari and Nice work
With those smaller bits I like to take several small passes with a higher feed rate.
Today I managed to make the upper cooler grill
