Old 01-24-2013, 06:29 PM
tracksntreadslou's Avatar
Default Re: CAT 374D L
Coming along Nicley Ari ..Your attention to detai is awsome ..Pretty much giving it your own signature with all the little changes ,extras and add ons ..When your milling out the smaller holes can you pretty much cut through the thinner guage material or do you have to make multi passes with those fine bits..Feed rates make a difference as well? Thanks Ari and Nice work
Old 01-26-2013, 01:39 AM
With those smaller bits I like to take several small passes with a higher feed rate.
Today I managed to make the upper cooler grill
Old 01-26-2013, 06:03 AM
Looks fantastic Ari! It won't be long now!
Old 01-26-2013, 06:33 AM
Thanks Reg, I hoping to get the hydraulics up and running in few weeks, just missing filters and the tank.
I'm anxious to see how my cylinder will hold the pressure
To be honest there's still a lot to do, and it always seems to get harder and harder towards the end.
Here's the lower grill
Old 01-28-2013, 03:13 AM
ihbuilder's Avatar
awesome job so far Ari . Question, did you order your internal gear online ? The site states they only except online payments from the UK . And of course , the 1's I need are not in stock .
Old 01-28-2013, 07:09 AM
Yes I did. They will send you a invoice to your email and you must pay that in advance.
It's simple to do in Europe when using those IBAN and BIC numbers but I don't know if are you able to use them when paying from outside EU.
Old 01-28-2013, 08:11 AM
ihbuilder's Avatar
OK I'll try them again . worst case I cut them myself . I already have it programmed . It's just a good couple hours to cut in the mill in steel .
Old 02-18-2013, 06:49 AM
if you need anyone in the UK to order stuff and forward it on, then let me know, don't mind helping fellow modellers out..
Elliot
Elliot.
Old 02-18-2013, 07:12 AM
ihbuilder's Avatar
Elliot
I'll keep that in mind Elliot thanks for the offer . I found a co. state side that has 1 in stock . Same price when converted .
great job so far Ari your truly an inspiration for me to get my but in gear and get 1 of mine done
