Old 04-05-2013, 01:41 PM
Semi Crazy's Avatar
Semi Crazy Semi Crazy is offline
Semi Crazy is on a distinguished road
Default Re: Wedico expert needed!
I have trucks with and without the coupler. They seem to work the same other than the pulling torque and slow movement abilities. No difference in battery draw that I have ever noticed. I did eliminate one of mine because of the new Behler motor differences.
If I'm not mistaken the gear on both units is the same. Possibly white? When I get home tonight I will send you a PM with a Wedico instruction page on the coupler. That should answer your questions.
Good luck with your Wedico truck, post some pictures.
